MPC6502 fuser to an MPC8002
  • digicor
    • Jul 2008
    • 1159
    Is there anyway to make the C6502 fuser convert and work in a C8002?
    i know it fits right in but it wont recognize it , i know this, but is it a pin in the connector that can be switched?
    or it just wont work?
    i have a like new fuser from a 6502 and need one for the 8002...
    Thanks for any info
    • 37628
    Re: MPC6502 fuser to an MPC8002
    The major difference is the voltage. The C6502 is a 120Volt model where as the C8002 is a 240Volt. The same goes for the pressure roller lamps and Induction Heaters. There is either a jumper on the connector or an ID chip on the fusing unit frame to protect against blowing the 100V lamps and IH coils should you put a C6502 fusing unit into a C8502.
    • digicor
      • Jul 2008
      • 1159
      then it just cant be done, Thanks i figured as much but i tought ide ask
      • butcher
        • 48
        Thanks for any info
        Hi Mate,
        I'm pretty sure these are the same animal, the only difference being the C6502 being a 65ppm unit and C8002 being an 80PPM unit.
        From where I am ( Australia ) , The fuser is the same.
        • davel
          • Oct 2011
          • 1108
          Everything 240v in Oz, I think both need to be on a 15A outlet, different voltages in US must be a pain.
            • 37628
            Originally posted by butcher
            Hi Mate,
            In Australia YES. But the person asking is in North America. Check your Parts Catalog and you will see that for North America (NA) the C6502 fusing unit, pressure roller heater and IH coil are different.
              • 37628
              I have worked on both. The customer who got the C8502 was actually a Ricoh ship in but Ricoh failed to tell them that it would require 240 Volt outlet. Had to delay delivery and setup a day while they got an electrician out to install the required circuit.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Thanks for any info
                In the uk they are the same fusers 100% I would of thought if both machines would of been made for the usa the ie 120 volts they would be the same but slimslob is in usa and has the correct part manual so he may be correct good luck.
                Regards Mark
                • skinnyb
                  • Jul 2008
                  • 291
                  Definitely different in US. 6502 is 120v and 8002 is 208v. It is a pain especially upon initial install when the customer doesn't have the correct power...
                  Sent from my LM-V405 using Tapatalk
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Thank you for confirming skinnyb I knew slimslob would of be correct {he is most of the time} different voltages sounds like we a bit better of having 240v. Stay safe
                    Regards Mark
                    • digicor
                      • Jul 2008
                      • 1159
                      Hi Mate,
                      it fits it just says "re set fusing unit" or something like that, it does not see it as installed.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        As slimslob and skinnyb said in the usa THEY NOT compatible
                        Regards Mark
                          • 37628
                          Most machines that I have worked on that have different fusing units for NA 120 volt and everyone else 240 volt have a jumper on the fusing unit that tells it what voltage the fusing unit is for. 120 volts heaters last about 5 seconds when hit with 240 volts. On the other hand 240 volt lamps will not reach operating temperature at 120 volt. Had a new tech order an international sleeve for an 03 once.
                          • fshead
                            • 2378
                            why not swap out the fuser lamps from the bad fuser to the new one?
                            • anothertech
                              • 1771
                              Might be better to take all of the good parts from the new fuser to rebuild the used fuser.
