Paper Jam on Fuser Unit Ricoh mpc3002
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi everyone,
    Does any one has the idea what would be the cause of paper jam on fuser unit??
    Attached is picture.
  • 8T2
    • Aug 2015
    • 257
    Re: Paper Jam on Fuser Unit Ricoh mpc3002
    Some more info please? Picture not too clear on my mobile with a broken screen lol. What model is it? Total counters? PM counters?
    It looks like a MPC 3002 or similar, My money is on the sleeve being dried out if it is
    Sent from my WAS-LX1 using Tapatalk
    • davel
      • Oct 2011
      • 1107
      Jam code?
      • FrohnB
        • Jul 2017
        • 1919
        Does it make a grinding noise?
        Have had many of these where the Pressure Roller gear or the Idler gear deteriorates, and can cause jamming in the fuser.
        Do you have Correct size/orientation settings in paper tray?
        What's the jam code?
        Omertà
        • skinnyb
          • 291
          This all day. Any strange noises? Does the paper make it to the other side of the Fuser? Wrinkled edges? Not enough into to help you. I would venture a guess that unit needs rebuilt (new sleeve and pressure roller).
          Sent from my LM-V405 using Tapatalk
            • 8182
            Originally posted by Pixtech Frameworks
            Hi everyone,
            I guess you are an end user?
            What is the PM life of the sleeve?
              • May 2020
              • 238
              It makes grinding noise. No code, trying to do color pattern.
                • May 2020
                • 238
                Paper size correct, grinding noise.
                  • May 2020
                  • 238
                  The sleeve is almost new and grinding noise when rotating. Pressure roller seems good.
                  • anothertech
                    • 1771
                    How do the fuser gears look?
                      • May 2020
                      • 238
                      Looks ok and new.
                        Looks ok and new.
                        "looks" what is the page count?
                        is it OEM NEW or a rebuilt unit?
                        pull it out and check for toner buildup
                          • 8182
                          ​My money would be on aftermarket sleeve ........
                            +1 on that brother
                              • May 2020
                              • 238
                              I found the solution guys, the pressure roller was damaged. I replaced it and everything is perfect now.
                              Thanks great technicians
