Mpc 5501 sc204
  • mikadonovan
    • May 2008
    • 2931
    Re: Mpc 5501 sc204
    Before I retired I had them all on my laptop that went everywhere I went.
    Just this last year I put my service docs onto a flash drive that I always have with me. I rarely have to use my laptop these days (Although I do need it for onsite firmware SD card prep).
    NEVER ASSUME ANYTHING
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: Mpc 5501 sc204
      Originally posted by mikadonovan
      Toner Munkeh posted this in 2012:
      Re: SC 204 MPC4000
      This code can also be caused by something really sneaky. At the bottom of the paper transfer unit there's a bar with two wedges on the end that stop the unit moving too far forward, allowing you to close the side door without having to push the unit back manually. Either side of this bar there is a spring. Check to see they haven't been dislodged.
      Also, the green earth wire on the PTR assembly can break causing SC204.
      Hit it.
        Re: Mpc 5501 sc204
        I just clicked on this thread for the first time. What in the world? lol
        • FrohnB
          • Jul 2017
          • 1919
          #19
          Re: Mpc 5501 sc204
          Check the Green Ground wire that runs from the right-hand door to the frame of the machine. We have had a ton of calls for that wire breaking and causing mirror motor codes.
          Are you using the correct Transfer roller?
          There is a white ground wire that attaches to the metal frame part of the Transfer case and the other side is screwed down by the sensor in the case, is this wire missing or not screwed down?
          Omertà
          • mrfuser
            • 1604
            #20
            • anothertech
              • 1757
              #21
              Re: Mpc 5501 sc204
              The one time I had this problem, it was that white wire was detached at one end.
              • anothertech
                • 1757
                #22
                Re: Mpc 5501 sc204
                I use my laptop multible times every day checking tech pubs, firmware, knowledge base, forums, parts, service manuals. How do you get by without it?
                • mrfuser
                  • 1604
                  #23
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    #24
                    Re: Mpc 5501 sc204
                    Knowledge is power best to keep everything on laptop or tablet etc save on return calls most important things to carry all the time complete tool case, hoover, laptop.
                    Regards Mark
                    • mrfuser
                      • 1604
                      #25
                        • 37059
                        #26
                        Re: Mpc 5501 sc204
                        They are being stolen for their platinum content. The platinum is also why they are so damned expensive to replace.
                        • mikadonovan
                          • May 2008
                          • 2931
                          #27
                          Re: Mpc 5501 sc204
                          The most common thing I have to reference onsite is error codes, which I have on my phone. I have a laptop in the car, I just don't need it most of the time. Half my time is in the office, and my PC is handy for these things.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            #28
                            Re: Mpc 5501 sc204
                            I keep all service information bulletins manuals firmware everything on phone & tablet sd card and pc all sync with Dropbox best to have everything to hand
                            Regards Mark
