Ricoh MP3353
  • tcypy1961
    • 773
    [CQ] Ricoh MP3353
    Customer is using copier mainly for printing yet has been noticing when copying copies are lighter than prints. Initially I cleaned copier to no avail adjusted SP2201 with not much difference. I replaced the drum and drum blade didn't change much. There was an adjustment on the Ricoh Aficio 1022 I believe SP5106 that helped in making copies darker yet it's not in this copier. Looking for help in this; to darken copies.
    Had customer print out sample which came out good yet when copy was made some solid areas were somewhat washed out. From what I saw I would think if it were the drum and or unit it would do so in print jobs as well.
    Thanks!!!
  • sandmanmac
    • 3981
    Re: Ricoh MP3353
    Thanks!!!
    There are countless threads about the issue of good copies and light prints as the PCU approaches end of life on machines from way bask to AF1022/27 thru the xx53 series
    SP2907-001 thru 005 is the SP mode that you're looking for, that will improve the copy quality as the PCU gets close to end of life. The default is 5. Setting them to 7 or 8 usually does the trick for me.
    Question: When the copy quality faded, why would you only replace the drum, and not the Dev? It takes 5 minutes more, and Dev has been the primary causes of light copies since the beginning of time
    • tcypy1961
      • 773
      Re: Ricoh MP3353
      Customer didn't want to spend the money(most my customers have tight pockets) and after replacing drum and finally getting to see samples I felt PCU would not have solved issue. One thing I've found in my 36 years developer only goes bad if not used or gets bad toner put in it. Most my copiers are using the original developer in copier and copies are fine. To be honest with this copier the copies are fine to me could use a little contrast.
      Thanks for your help!!!
        • 37502
        Re: Ricoh MP3353
        Normally when copying starts to get light but printing does not it means that there is dust, toner or some other filming on the mirrors and even the under side of the platen glass. This will cause it to see a darker color when doing white reference during initialization. As a result the entire gray scale gets shifted.
        Turn the power off. Remove and clean both sides of the platen glass and the bottom of the scale which is where the white reference is. Also clean all three mirrors. Be careful with the mirrors as they are super to scratch. Also clean the lamp reflector.
        Reassemble and turn power back on. 9 times out of 10 the light copies will be gone.
        • sandmanmac
          • 3981
          Re: Ricoh MP3353
          I was assuming that he would have done that, but after finding out that he feels that developer almost never goes bad, I should have assumed nothing
            • 37502
            Re: Ricoh MP3353
            I had a instant where there was dust under the scale only.
            • tcypy1961
              • 773
              Re: Ricoh MP3353
              all this was performed before deciding to replace the drum. Had I been shown the samples on my first trip I would not have replaced the drum.
              Thanks!!!
              • anothertech
                • 1771
                Re: Ricoh MP3353
                This is very common on this model group. The developer needs to be replaced.
                • tcypy1961
                  • 773
                  Re: Ricoh MP3353
                  I would agree if problem was with prints as well as copies. Can that be explained???
                  Thanks!!!
                    • 37502
                    Re: Ricoh MP3353
                    Thanks!!!
                    There is the fact that there is a difference in the laser intensity between printing and copying. Higher laser intensity during printing makes for darker blacks.
                    • copyaction
                      • Oct 2007
                      • 991
                      Re: Ricoh MP3353
                      Thanks!!!
                      As was already mentioned this has been a common problem since the 1022 series.
                      The question is how many copies on the developer?
                      If it is over 60,000 it is definitely suspect.
                        Re: Ricoh MP3353
                        +1. Some needs to review the manual.
                        • copier tech
                          • 8153
                          Re: Ricoh MP3353
                          Thanks!!!
                          Replace the developer if at or near PM life.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Re: Ricoh MP3353
                            Thanks!!!
                            Clean the optics
                            Regards Mark
                            • aalex_bom
                              • Jan 2008
                              • 214
                              Re: Ricoh MP3353
                              Originally posted by mga
                              Clean the optics
                              But Drum or PCU will be replaced after that
