ricoh mpc2050, problem in duplex printing.
  • tullio
    • Feb 2012
    • 268
    black drum, original black developer same problem. new transfer sheet same problem. new black original toner same problem.
    double-sided printing only.WhatsApp Image 2021-02-04 at 19.21.47.jpgblack drum, original black developer same problem. new transfer sheet same problem. new black original toner same problem.
    black drum, original black developer same problem. new transfer sheet same problem. new black original toner same problem.black drum, original black developer same problem. new transfer sheet same problem. new black original toner same problem.problem in duplex printing.
  • GIUBOSS
    • 1435
    Re: ricoh mpc2050, problem in duplex printing.
    If you only have the problem with black you should still double check both the drum assembly, charge roller, wax bar. How many copies does the fuser have?
    is the firmware updated?
    • luca72
      • Oct 2017
      • 1778
      Originally posted by tullio
      black halo.[ATTACH=CONFIG]48143[/ATTACH]
      double-sided printing only.[ATTACH=CONFIG]48144[/ATTACH]black drum, original black developer same problem. new transfer sheet same problem. new black original toner same problem.
      I had the exact same problem on the mpc2051, among other things the one we use here in our office, I remember that I had changed everything, pcdu, laser, transfer unit, etc ... you have to change the PTR roller, or in any case also check that the pressure mechanism between ITB belt and PTR roller is correct, i have solved it only with the PTR roller.
      let me have feedback
      regards
      "I'll be back"
      • tullio
        • Feb 2012
        • 268
        [QUOTE = luca72; 1681261] Ho avuto lo stesso identico problema sull'mpc2051, tra l'altro quello che usiamo qui nel nostro ufficio, ricordo che avevo cambiato tutto, pcdu, laser, transfer unit, ecc ... hai per cambiare il rullo PTR, o comunque controllare anche che il meccanismo di pressione tra cinghia ITB e rullo PTR sia corretto, l' ho risolto solo con il rullo PTR.
        lasciatemi avere un feedback per
        quanto riguarda
        I try to replace the transfer roller.
