Ricoh MPC5502 Parts Manual
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Ricoh MPC5502 Parts Manual
    Hi Guys, hope someone can help, I went to one of these machines today and when they feed an original through the document feeder, rather than it being fed back up from the glass through the exit section, the paper goes straight on ending up as a jam under the white plastic platen piece. Im not that familiar with these machines but to me it looks as if something is missing, like a mylar sheet or something? I have access to My Ricoh (although dont use it that often) and have trid to download the SPDF parts manual but for some reason the download doesnt seem to work? so I am either looking for a parts manual for the document feeder or someone to say ' hey i know what that it, you need to do .....................................
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ricoh MPC5502 Parts Manual
    You can't use chrome browser when downloading pdf's from ricoh at the moment use
    Regards Mark
      • 37047
      Pm me with your email address and I can send you the parts manual.
      • anothertech
        • 1757
        I do it every day.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Originally posted by anothertech
          I do it every day.
          Not in the uk at the moment there a problem with my ricoh with chrome it says it on my ricoh homepage
          Regards Mark
            • 8119
            This was the top link on google when I searched for 'Ricoh MPC5502 Parts Manual'
            Oooops, looks like the page you requested could not be found. Please check the URL for proper spelling and capitalization.
            • MIGUELMARCHENA
              • Feb 2018
              • 185
              It would be good to see a photo of where the jam is, because perhaps the small glass, was badly placed, with the rubber left, or the lid was raised and prevents the passage of the sheet
              it's a humble suggestion
              • luca72
                • Oct 2017
                • 1709
                if you don't know that model well, and look at the 3d manual, you don't understand anything, anyway (I go by heart) if I remember correctly that defect does it when the white belt unit is unhooked / positioned incorrectly, and the door immediately to the its right, under the spdf, and above the slide.
                • Leebs14
                  • Feb 2014
                  • 457
                  PHOTOS ATTACHED, it shows the paper not going back up through the exit guide, its like there is something mssing like a mylar?2.jpg
                  • luca72
                    • Oct 2017
                    • 1709
                    something else came to mind.
                    is it not that the customer has removed the original white cover from the rdf and has reattached it wrongly?
                    detach it completely, place it well on the glass, with the corners adhering to the brackets, and then close the rdf by pressing lightly
                    • Leebs14
                      • Feb 2014
                      • 457
                      is it not that the customer has removed the original cover (D412 4911) from the rdf and has reattached it wrongly?
                      do you mean the white plastic sheet which is fised to the underneath of the document feeder by velcro?
                      • luca72
                        • Oct 2017
                        • 1709
                        exactly, that you detach it completely, and put it back using the correct procedure, that is, you place it well on the glass so that both corners of the brackets touch it, and close the rdf
                        many customers detach it, and put it back badly, they will never be able to center it without using the above procedure
                        I uploaded you a short video on youtube, so you can see quickly
                        Ricoh mp copiers correct cover set procedure - YouTube
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          PHOTOS ATTACHED, it shows the paper not going back up through the exit guide, its like there is something mssing like a mylar?[ATTACH=CONFIG]48470[/ATTACH]
                          Looks like the white platen board in on skew
                          Regards Mark
                          • luca72
                            • Oct 2017
                            • 1709
                            to me too, it seems misaligned, but maybe it's the perspective, he would have noticed! we have a technician mr.magoo 2! .. LOL
                            also in the video that I made him on the fly
                            (a couple of answers above)
                            it seems out of line
                            • fshead
                              • 2356
                              i think the metal white piece is backwards..I dont have one to reference here..
