Ghosting on the text?
  • lurker1652
    • Mar 2021
    • 58
    Hello!, testing an MP C306 I see a weird ghosting on the text, as if the text was all bold or something like that.
    Any hints on what needs to be adjusted?
    Re: Ghosting on the text?
    do a color calibration/registration.
    what is the life on service parts? drum/fuser/belt/dev
    when did the problem arise?
    being an end user you might want to hire a TRAINED tech.
      • 37556
      That can happen if you are not using Genuine Ricoh supplies.
        +1
        I have to STOP ASSuming people have realized crap toner doesn't save them a damn penny.
          • 23010
          It's awfully regular. Are you sure that this isn't just a font with shadow?
            • 16455
            That's what I was thinking. That's some beautiful bold text.
            • luca72
              • Oct 2017
              • 1791
              PTR roller
              "I'll be back"
              • mikadonovan
                • May 2008
                • 2931
                You might clean the ID sensors and run ACC before doing anything else.
                NEVER ASSUME ANYTHING
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Does it repeat what the pm lifes can up load full page.
                  Does it only happen on bold text
                  Regards Mark
                  • mrwho
                    Major Asshole!
                    • 4299
                    Any of the above hints are valid. Question is: was that printed in Full Color or Grayscale? Does it happen in both cases?
                    If any of the above suggestions fails, check the fuser unit (but I don't believe that too much).
                    Mascan42
                    Ibid
                    • lurker1652
                      • Mar 2021
                      • 58
                      It came home like that, second hand unit. Have to look at those metrics and share back.
                      Happens with color printing, black printing is fine.
                      Auto Color Calibration didn't help.
                        I am offering no more help until you answer ALL the questions posed to you by myself and everyone else.
                        We are not there.. you are. if you can't give us the valid info we need to help you, then go hire a trained tech.
                        I'm done.
                          then if ACC failed I would start by cleaning the density sensor
                          • anothertech
                            • 1771
                            Does it only do it when printing, or does it do it when copying too?
                            • lurker1652
                              • Mar 2021
                              • 58
                              Well, I'm not sure anymore.
                              The print that derived to my post was sent from an Android phone with a driver that made all letters color based (Samsung printing app).
                              Then I tested:
                              - Ricoh Smart Device App: It correctly printed blacks as blacks, and colored as colored (no color mixing to get black)
                              - Linux laptop with Ricoh PDF driver: same, blacks were blacks, and color, color.
                              To the left original Android print (color), to the right Linux print (all black)
