Ghosting on the text?
    • 23010
    #16
    Re: Ghosting on the text?
    It sorta sounds like a font substitution, yes? =^..^=
    • lurker1652
      • Mar 2021
      • 58
      #17
      I am offering no more help until you answer ALL the questions posed to you by myself and everyone else.
      We are not there.. you are. if you can't give us the valid info we need to help you, then go hire a trained tech.
      I'm done.
      Hello!, actually I was not there, now I am
      Looking for how to get the aging you asked for, please bear with me.
      • lurker1652
        • Mar 2021
        • 58
        #18
        Talking about tests, tried to print some text from the Linux machine, they don't look that bad "live". Pictures seem to be a lttle ugy at 43% of zoom (cannot upload original files)
          [ATTACH=CONFIG]48762[/ATTACH][ATTACH=CONFIG]48763[/ATTACH]
          you're not able to scan to a PDF file?
          then upload via your computer?
          • lurker1652
            • Mar 2021
            • 58
            #20
            Well, I'll stop uploading pictures than and go back to fixing the scan to CIFS share then. That's another pending poing (even with latest firmware & proper protocol support it seems to be broken), last time I checked it was DNS related (even though properly configured, the printer doesn't seem to use DNS to reach the share).
            • anothertech
              • 1771
              #21
              Well, I'm not sure anymore.
              The print that derived to my post was sent from an Android phone with a driver that made all letters color based (Samsung printing app).
              Then I tested:
              - Ricoh Smart Device App: It correctly printed blacks as blacks, and colored as colored (no color mixing to get black)
              - Linux laptop with Ricoh PDF driver: same, blacks were blacks, and color, color.
              To the left original Android print (color), to the right Linux print (all black)
              [ATTACH=CONFIG]48761[/ATTACH]
              I have been seeing this a lot lately, it's always been the customer using the wrong print driver.
              • lurker1652
                • Mar 2021
                • 58
                #22
                do a color calibration/registration.
                done, no joy
                what is the life on service parts? drum/fuser/belt/dev
                is that information available on the machine?, cannot seem to find it.
                d
                when did the problem arise?
                Doing a test from the Samsung printing app for Android. Seems to be client/driver specific
                being an end user you might want to hire a TRAINED tech.
                There's only one Ricoh partner locally, and they only service machines they've sold (it's no the case). I was referred to other freelancer technicians in the past with bad results in general.
                • lurker1652
                  • Mar 2021
                  • 58
                  #23
                  Hope it's only that, as I mentioned, printing with other clients worked fine (Linux+Ricoh PDF driver & Android with Ricoh Smart Device app)
