mpc3003 offset (ghost image) after sleeve unit replaced
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    Selecting medium thick, problem solved.
    Firmware downloaded via old my-ricoh.com (not octopus, demand for account today).
    Is this engine firmware up to date: D1475504F 1.42:08 16/5/2020 ?
    Thank you (again) for your help.
  • copier tech
    • 8174
    Re: mpc3003 offset (ghost image) after sleeve unit replaced
    Originally posted by Mark Bbb
    Hoi,
    If this happened after you replaced the fuser sleeve retrace your steps.
    Also what part number sleeve did you replace?
    • Mark Bbb
      • Jun 2012
      • 1662
      D1464042
      We buy many machines from auctions, so we don't know their history, and mostly they have these weird troubles.
      But in fact only on the mpc3003 series, we have no trouble with all other models.
      • ridgemill
        • Sep 2017
        • 190
        Only time we have had the new belts not fusing is due to a broken lamp, or the thermal fuse needing resetting.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Hoi,
          There is a cold offset RTB for this you could try that also
          Not oem tonermpc2003/4 to mpc 6003/4 series adjust
          3612-131-132-133-134 K.,C,M&Y
          SET ALL TO 600
          Regards Mark
          • Mark Bbb
            • Jun 2012
            • 1662
            Is this the latest engine firmware?
            • Mark Bbb
              • Jun 2012
              • 1662
              If this would be the case, the machine would give an error code like sc542 or something like that.
              • Mark Bbb
                • Jun 2012
                • 1662
                Hey guy's, don't let me down!
                • Polo-022
                  • Sep 2007
                  • 486
                  Nope, never!!
                  This is the latest Engine firmware you mentioned above..
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    UPDATE
                    Medium thick paper setting will solve all problems at once, without replacing anything.
                    If setting on normal paper, and replacing pressure roller, sleeve roller and exit guide (bent) will solve the color smear (smudge?), but not the black offset (solid black).
                    Offset will be less (but not totally solved) using parallel black toner.
                    => fusing matter.
                    But i already tested with higher fusing temp, no good.
                    Firmware is up to date.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Did you perform the procedures listed in tech bulletin 30 as MGA suggested? It specifically addresses this issue.
                      NEVER ASSUME ANYTHING
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Sorry, forgotten to mention.
                        Yes i did, no good.
                        Just 5 minutes ago a customer complained (again) for smear.
                        I have refurbished the F.U. with a new sleeve and new PR.
                        No good!
                        Medium thick seems to be the only solution so far.
                        Do you encounter the same problem?
                        • anothertech
                          • 1771
                          Yes i did, no good.
                          No good!
                          Can you go into service mode and find the fuser settings for the different types of paper? Just take the settings for medium thick and apply them to plain paper.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            I tried to find this info in the serv man, i can't find it.
                            How do you cope with this problem?
                            • davel
                              • Oct 2011
                              • 1107
                              Get a better manual. SP 1105
