MPC 3002 paper exit problem
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Misc] MPC 3002 paper exit problem
    Hi friends, My machine mpc3002 got problem when paper come out from exit section it's getting rolled up like i attached the image. If anybody knows how to solve this problem please teach me. Thank you.
    • 8138
    Re: MPC 3002 paper exit problem
    Most likely the paper is damp so try a new packet of paper or you have the wrong paper weight setting used.
    • Gift
      • Mar 2011
      • 2459
      Lol print quality does also not look very nice
      It's indeed an issue with the paper/enviroment - you can try to mc-gyverfy* the internal output tray or order the modified one (I think that came with the MPC3002 IIRC)
      *If you have some trash ricohs, then rip of a duplex paper output thingy that's below the scanner and put it on the paper output tray. Find a good position and use a little hot glue.
      • kanagavel
        Service Engineer
        • Feb 2020
        • 78
        Hi friend thank you for your reply. I try with new paper also same problem coming.
        And what paper weight setting?
        And how to do that, can you please teach me.
          • 8138
          If you are using 80gsm paper check the tray setting is set to 80gsm.
          Changing Paper Thickness Settings
          • kanagavel
            Service Engineer
            • Feb 2020
            • 78
            Hi friend thank you for your reply. Can you
            Teach me how to the setting.
            • Gift
              • Mar 2011
              • 2459
              -> Insert Picard Facepalm here <-
              • SteinarN
                • Apr 2021
                • 114
                Here you have a link where you can download the user manual in different languages.
                You need to go into system settings>paper tray settings
                I dont know in detail for your machine, but you should find all those settings explained in the user manual.
                MP C3004/C3504 series download page
                  • 8138
                  Click on the link I posted!
                    • 8138
                    Some people are beyond help 🤣
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 191
                      in South America, they even falsify the paper
                      here it says to be 75 grams, but it's a lie
                      It looks like newspaper or tracing paper of up to 60 grams, so it will come out just like it happens to you, wavy.
                        • 37448
                        Was it actually "NEW" paper still sealed in an unopened wrapper stored where it would not be exposed to moisture.
                        • kanagavel
                          Service Engineer
                          • Feb 2020
                          • 78
                          Ok friend thank you. I will try this.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            It is also possible that not original Ricoh toner will result in paper curling.
                            Is the toner original Ricoh?
                            • luca72
                              • Oct 2017
                              • 1762
                              maybe the eye deceives me, but it seems that that sheet has been used over and over again (?), it could be the "limp" pressure roller that bends the paper
                              "I'll be back"
