RICOH MP C4502 dirty blade in fuser unit
  • tecnodue
    • Oct 2020
    • 7
    Hallo,
    i often find the separation blade in the fuser unit dirty of fused toner that goes on the sheets.
    What shall i do?
    Thank you
  • copier tech
    • 8190
    Re: RICOH MP C4502 dirty blade in fuser unit
    Originally posted by tecnodue
    Hallo,
    What shall i do?
    Thank you
    This is the stripper plate some techs remove this to prevent toner build up damaging the sleeve.
    • Polo-022
      • Sep 2007
      • 486
      Hallo,
      What shall i do?
      Thank you
      Use original toner for better results : more prints, less wasted particles.
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Original toner AND good paper!!!! When there is too much dust (chalk, etc...) in the paper this problem occurs much faster.
        Customers with good paper allways reached the real end of fuser life without a dirty stripperplate.
        Greetings...
        • mikadonovan
          • May 2008
          • 2931
          Cleaning the stripper plate is a procedure outlined in the manual, and is needed on occasion. More so with aftermarket toner. Nothing unusual.
          NEVER ASSUME ANYTHING
            Originally posted by Zeldaman
            Hi there!
            Greetings...
            QUALITY supplies = Quality Output
              • 37556
              The blade is coated with a thin layer of Teflon that is supposed to help keep toner from sticking. Improper cleaning can damage that coating and make things worse. If that has already happened you will need to replace the blade.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Hallo,
                What shall i do?
                Thank you
                Tell user to stop using rubbish toner use oem if plate is damaged ie Teflon gone fit new one you could remove but you will get fuser jams paper wrapping around sleeve
                Regards Mark
                • luca72
                  • Oct 2017
                  • 1791
                  interesting, usually I scratch the edge of the blade, with fine sandpaper, moving it away from the sleeve, without disassembling anything, I have never had problems with this procedure, however as soon as I have the opportunity, I will do this experiment to remove it too....however, we use only ricoh genuine toner
                  "I'll be back"
