MPC 5504 Ex Service Lock and Changed Passwords
  • skynetto
    • Sep 2012
    • 257
    #31
    Re: MPC 5504 Ex Service Lock and Changed Passwords
    We simply replace the NVRam with a new one when faced with this issue.
    Thats also an option but you lose counters and other settings i guess.
    I bought my reader 5 years ago and it payed itself thru the years.
    • copier tech
      • 8133
      #32
      Yes machine goes back to factory default so last resort.
        • 37422
        #33
        You can always print the counter sheet and keep it with the machine service history.
        • Elmo
          • Feb 2010
          • 541
          #34
          Hi all
          i got a cheap usb chip reader and managed to get a data dump from Nv ram 1 on the locked machine
          and a data dump for a freshly reset machine so i can compare the 2
          so it is possible to obtain a data dump direct from the nv similar to uploading to and sd card via sp mode
          unfortunately the cheap reader didn't last very long lol
          so its worth getting a reasonable 1 very handy device to have
          Special thanks to Skynetto for his help and advise
          I Used To Live To Fix Things Now i Fix Things To Live
          • tsbservice
            Field tech
            • 8000
            #35
            Originally posted by Elmo
            Hi all ...
            I see U even can rep up him.
            • luca72
              • Oct 2017
              • 1759
              #36
              Hi all
              Im looking for some advice/help
              i have a few ex lease MPC5504ex that have service lock enabled and have had both supervisor and admin passwords changed and iam unable to get the password from previous owners
              i want to data dump the nv to see if i can edit the passwords and gain access to the machine
              i have a machine that ive cleared passwords in sp mode so i can back up that nv to sd card and use that as my guide to what i need to edit
              so advise
              what is a good eprom reader and program to use to read then write back to the nv
              i have a usb eprom reader that i have used in the past on older models
              i use HxD to edit the file is that ok
              Thanks in advance for any advice
              This is Only To Allow Me To Gain Access to The Machine's via supervisor or admin password change
              go wrong, you can try to ask a ricoh card repair service, our supplier can provide us with new nv-ram, with the counter reset, (for example mp2501 = 70euro if I remember correctly), many customers prefer them for simplify the invoicing of the prints, as I see that they are new models, I assume that the bodywork is immaculate and few prints, you can tell customers that they are not new but have been picked up from corporate events / shows, or in-store display, disassembly everything, give it a good clean, and the mc is like new, but for real!
              "I'll be back"
              • copier tech
                • 8133
                #37
                An old thread I know but ...........
                I have heard that to clear the NVram you can fit it upside down (incorrectly) then power on the device, especially useful if the SP entry code has been changed etc.
                Sounds very dodgy, just wondered if anyone has tried this!?
                • luca72
                  • Oct 2017
                  • 1759
                  #38
                  I, always do it...then it goes into Japanese, and after its reboots, it asks you for passwords, like when it's new out of the box.
                  Not upside down!!!, Put the nv-ram 1 in socket 2, and the 2 in socket 1!...if you repeat this, the reset process run again....as many time as you want
                  "I'll be back"
                  • sandmanmac
                    • 3980
                    #39
                    Very Interesting Luca!
                    Do you swap them back to their original spots after the reset or leave them?
                    • luca72
                      • Oct 2017
                      • 1759
                      #40
                      no, leave them as is, if you then invert them again (original position) it resets again, you can repeat this process indefinitely, it resets with each inversion.
                      "I'll be back"
                      • luca72
                        • Oct 2017
                        • 1759
                        #41
                        no, leave them as is, if you then invert them again (original position) it resets again, you can repeat this process indefinitely, it resets with each inversion....and try to print the counter...Surprise!!!...LOL..LOL!!
                        Keep present that the main nv-ram its the 2...i have a 4054 that run with only the nv-ram 2!...anyway, First the inversione, i suggest to you to save on sdcard the main data with sp nv-ram upload (dont Remember the sp in this Moment)...and After reset, sp data download
                        "I'll be back"
                          • 37422
                          #42
                          Unless service lock is preventing you from getting into SP mode to do the backup.
                          • copier tech
                            • 8133
                            #43
                            Interesting, thanks.
                            I guess you are using this method to reset the main counters ? (answer if you wish!)
                            Just to confirm you are referring to these two nvrams on the controller ?
                            NVRAM Location.pdf
                            • luca72
                              • Oct 2017
                              • 1759
                              #44
                              [ATTACH]59021[/ATTACH]
                              exactly, for billing reasons, some customers want it this way.
                              yes the nv-ram are those
                              "I'll be back"
                              • luca72
                                • Oct 2017
                                • 1759
                                #45
                                right!
                                "I'll be back"
