Having a recurring problem with some MP4500's that I service where the cleaning blades are failing prematurely causing the charge roller to develop a line that shows on the copy. In some cases the blades are only going a few thousand copies - not even close the the expected 150K yield. Any information on this particular problem is appreciated - thank you.
Caveman
Caveman
