MPC2504ex Sc843-02
  • Popolopo
    • May 2023
    • 110
    MPC2504ex Sc843-02
    Check the manual, SC843-02 say panel eMMC already rewrote threshold. Any way to reset it, instead of replacing the whole panel?
  • mfrigault
    • Feb 2017
    • 18
    See bulletin...
    • Popolopo
      • May 2023
      • 110
      Originally posted by mfrigault
      See bulletin...
      Well, the bulletin and manual say to replace it. I asking if there's a way to reset it. For example, we can format hardisk, can we do the same with the eMMc?
        • 37059
        There is no HDD or SSD on the Smart Operation Panel. If I were an android software engineer and had a complete set of the OS as implemented on the SOP, I might be able to reverse engineer it and come up with a way to clear the registers. Minimum charge to do so would be at least $5,000.00 and you would have to send the SOP to me to work on in my lab. It would most likely take 2 to 3 weeks.
        If you get really lucky Hytec Dealer Services might have already developed a method for their lab to fix the problem.
        • Popolopo
          • May 2023
          • 110
          Man. Ricoh really plan for obsolescence. Like it or not, need to buy new parts or machine.
          • luca72
            • Oct 2017
            • 1711
            It would be interesting to understand if there is a way to visualize the status of the R/W cycles before it reaches the limit
            "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
            • copier tech
              • 8121
              Have you tried updating the SOP cheetah firmware & performing a hard reset ?
