Check the manual, SC843-02 say panel eMMC already rewrote threshold. Any way to reset it, instead of replacing the whole panel?
MPC2504ex Sc843-02
If you get really lucky Hytec Dealer Services might have already developed a method for their lab to fix the problem.Comment
There is no HDD or SSD on the Smart Operation Panel. If I were an android software engineer and had a complete set of the OS as implemented on the SOP, I might be able to reverse engineer it and come up with a way to clear the registers. Minimum charge to do so would be at least $5,000.00 and you would have to send the SOP to me to work on in my lab. It would most likely take 2 to 3 weeks.
If you get really lucky Hytec Dealer Services might have already developed a method for their lab to fix the problem."loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)👍 1Comment
👍 2Comment
