IMC3500 SP mode Language
  • mtc-bah
    • Feb 2024
    • 14
    Hi everyone,
    the sp (service mode ) mode language is Japanese could you please help me to give me the method to change it to English
    thanks
  • copier tech
    • 8144
    Try updating the firmware, sounds like it has been updated with Japanese fw in the past.
    We can supply the latest (English) should you need it.
    www.printerfirmware.co.uk
    • copier tech
      • 8144
      Try updating the firmware.
      • dalewb74
        • Feb 2018
        • 1153
        one of our techs did this once. use google translate. then your phone should read it, display it in english then you should be able to locate it from there? i dont think you need firmware.
        • niticom
          • Dec 2011
          • 12
          Enter service mode (even if it is in Japanese) and go to SP 5807 then type 1 for N.A. (North America) then OK and exit. When you re-enter SP mode it will be in English
          • Popolopo
            • May 2023
            • 133
            Abit sus when just SP mode in japanese but front screen in english.
              • 37488
              Yes.Can often happen when a controller or NVram is replaced with a brand new one. The default off the production line is Japanese. Machines are configured before they are shipped, parts are not. The front panel language is stored on the front panel memory.
              • Popolopo
                • May 2023
                • 133
                i thought once change the language, both front and SP mode will follow the language we select at front
                  • 37488
                  Nope.
                  • mtc-bah
                    • Feb 2024
                    • 14
                    thanks for reply, if I chose North America or Europe error appears SC995-04 but error goes once I select Japan.
                    • troll0201
                      • Jul 2018
                      • 6
                      Machine ID
                      • copier tech
                        • 8144
                        What version firmware is the device on ? You can check with SP-7-801
