SC 285 RICOH IMC 6500
  • Exodia-P4
    • Jan 2023
    • 134
    Hello,
    I have a SC 285 on a Ricoh IMC 6500 (MUSIC ERROR).
    It can be a lots of things. I already clean the ID/MUSIC sensor, Change the ID/MUSIC sensor, check the ITB and OK...
    The process control is OK... tha calibration is OK, And every 2/3 days the error code reapears...
    Anyone already have this problem ?
    I join the Manual...
    Thank you
  • Larhal
    • 571
    Have you checked, upgraded the firmware?
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
      • 37488
      What did you clean the sensor assembly with? The recommended methods are either a soft camera lens brush with air bulb or a soft clean cotton cloth slightly dampened with water only. anything else can either leave a film on the sensors or actually damage the sensors.
      • Exodia-P4
        • Jan 2023
        • 134
        YES
        • Exodia-P4
          • Jan 2023
          • 134
          I cleaned the captors with cotton cloth... And after I replace it...
          • TonerMunkeh
            Professional Moron
            • 3865
            What sort of mileage does the ITB belt have on it?
            Hit it.
            • Exodia-P4
              • Jan 2023
              • 134
              The ITB have 55000 colors and 106000 Black... It's the printer counter (it have less than 1 year)
              • Exodia-P4
                • Jan 2023
                • 134
                No Ideas ?
                • menosmola
                  • Apr 2014
                  • 95
                  Check drum units, some unit may have hard movement...
                  • Exodia-P4
                    • Jan 2023
                    • 134
                    I checked them and I see nothing...
                    • dalewb74
                      • Feb 2018
                      • 1153
                      you said you have checked everything, and firmware is up to date. you have the manual. why not start at step 3 replacing parts? i mean the part in step 3 is what the sensors point at.
                      • anothertech
                        • 1769
                        Run the 2 dot test prints in service mode SP2. You con print out the color pages one at a time to see if one color is failing.
                        • Exodia-P4
                          • Jan 2023
                          • 134
                          I changed the ITB belt and the music sensor...
                          • Exodia-P4
                            • Jan 2023
                            • 134
                            The customer call today, AGAIN for the same problem I will try to change the laser unit but I dont know which one... HELPPPPPP
                            • sshayss
                              • Sep 2023
                              • 1
                              We are having this problem on multiple C6500s. No fix found yet.
