Ricoh MP5055 every morning SC672-21
  • DH1980
    • Mar 2009
    • 52
    Have a Ricoh MP5055 the customer reports SC672- 21 every morning. They power it on/ off and it is gone till next morning. Replaced the IPU board per Ricoh, Auto firmware is on.
    Thanks for any help.
  • dalewb74
    • Feb 2018
    • 1162
    have you checked that the firmware has updated?
    • luca72
      • Oct 2017
      • 1791
      the manual is very clear on that sc code "controller error", you can see that it has some problems when cold, no need to tell you to try to connect and disconnect it, because by replacing the ipu you have already done it.
      if you don't have another controller, try to replace at least the hdd, maybe you're lucky, and that was it... it already happened here.
      "I'll be back"
      • monstercopier
        • Jun 2019
        • 60
        I see it could be the USB cable. I replaced the USB cable to the SOP in the past. I am pretty sure it was 672-21.
        • sandmanmac
          • 3983
          I've had some SC672's that would temporarily reset with a reboot, resolved by replacing the HDD
          • anothertech
            • 1771
            There are 5 hits for sc672 in the firmware release notes.
            Also found this, worth a shot.
