MP C2003 Test Pattern Failed
  • Konik
    • Apr 2020
    • 16
    Hi guys.
    I have a small problem with the Ricoh MP C2003.
    When printing Test Pattern SP-1-103-002 it should look like this:
    I touch execute, the printout comes out and a small white Complete and Exit window appears
    The device I am currently testing, when I touch Execute, a small white window immediately appears. Failed and Exit, of course, no printing.
    When I try to print SP-1-103-001 it takes about 7 seconds and also Failed and Exit.
    There is paper in all 4 drawers and in the manual feeder. A4, A4R, A3. The device does not show any errors. I can copy in black and color, I can even print a test in user settings > maintenance > color calibration > copier function. Very nice print.
    The problem is that I need a Test Pattern printout for a client.
    I did Initialize All Settings & Addr Book SP-5-846-046, set new passwords but it still doesn't print my test
    Any ideas ?
    Reards.
  • lhmy
    • Oct 2023
    • 32
    Originally posted by Konik
    Hi guys.
    Any ideas ?
    Reards.
    not sure if we facing the same problem
    but in my case,the test pattern failed and also force line adjustment cannot be done
    I did swap the whole ITB unit and the issue is gone
    • luca72
      • Oct 2017
      • 1711
      Hi guys.
      When printing Test Pattern SP-3-012-002 it should look like this:
      Any ideas ?
      Reards.
      clean optic and id sensor inside the machine
      you must see sp 3-012 "ProCon ok?" display the result, if all 1111111 its ok, instead one of bit its different from 1 there is a error with that color.
      anyway you have easily some pcu strongly worn.
      3012
      [ProCon OK?]
      2 cifre per colore da sinistra, nell'ordine YMCK
      *read the chapter in the maintenance manual sp
      • Konik
        • Apr 2020
        • 16
        Hello and thank you all for your help.
        Of course I checked ProCon ok? and all results were good. I also did the ProCon 1-5 test. All tests successfully.
        I may not have much experience with Ricoh, but I do have experience with photocopiers in general.
        The device has about 15,000 prints, the test I printed in user settings > maintenance > color calibration > copier function is very nice, gradation ok, saturation ok, all colors in the x and y axis. My intuition told me that it was something in the administrator or other settings that was blocking the printing of the test. I made SP-5-846-046 again and additionally from SP-5-801-003 to SP-5-801-025 (only available functions). After this reset, it prints the test pattern ")
        Thank you again.
        I have another problem, this time with MP C3004.
        I will write another Topic.
        • dalewb74
          • Feb 2018
          • 1125
          firmware update? why would you initialize the address book in order to get a test print? or did anything with passwords? that has nothing to do with printing a test pattern in SP mode. i got into SP 2###-## mode. and that is where i find the test pattern print.
            • 37052
            Based on the thread he started today, I have a feeling that he or someone else who works with him has been dicking around where they shouldn't and have screwed the pooch.
            • csuka
              • Sep 2022
              • 2
              Change paper type plain in user tools
              • dalewb74
                • Feb 2018
                • 1125
                i certainly wouldn't argue with you on that one. lol
