Hello folks, Asking for some input again. As always, I appreciate any and all responses. We just put an MP9003 out in the field in good shape. We received a call, telling us that when someone goes up to the unit to make a copy, It goes thru a long warmup which is very frustrating. Obviously it's after it hasn't been used for a little bit. All the energy settings are maxed out. I never ran into this before. Could it be going into some kind of "auto shut off" ?? Or is this common on these big machines?? I looked thru all the settings, and did not see anything. Thanks in advance, Laser801
MP 9003 with constant long warmup
Define long warmup. Thats a 90 ppm copier with a heavy fuser. Check the specs in the manual for warmup. It's been a while since i worked on 6002 but from dead cold they were a few minutes from what i remember.
Don't let them turn off the energy save etc or max the counters. Fusers sitting cooking all day just wreck the fuser and adjacent areas. If that machine sits for long long periods and then they expect a quick copy, they have the wrong machine. That thing is not meant for 1-2 page jobs. It's meant to run.Evil will always triumph because good is dumb.👍 6 -
Normally, when you power up, its about 4 mins to ready. This is in a Law office and there are many attorneys that like to run up to the machine and make some quick copies. This is where their problem is with the warmup time. We replaced a 7503 which is a big unit as well but not the 20 amper. That unit did not do this. Maybe it is the wrong machine for that location.Comment
Normally, when you power up, its about 4 mins to ready. This is in a Law office and there are many attorneys that like to run up to the machine and make some quick copies. This is where their problem is with the warmup time. We replaced a 7503 which is a big unit as well but not the 20 amper. That unit did not do this. Maybe it is the wrong machine for that location.👍 6Comment
This is normal for the MP 9003. Updating the firmware does help but the fuser is the 'old school' heavy hot roller. The 9003 is designed to be run a bit like a production device, not 'one off. prints.
👍 3Comment
Hello folks, Asking for some input again. As always, I appreciate any and all responses. We just put an MP9003 out in the field in good shape. We received a call, telling us that when someone goes up to the unit to make a copy, It goes thru a long warmup which is very frustrating. Obviously it's after it hasn't been used for a little bit. All the energy settings are maxed out. I never ran into this before. Could it be going into some kind of "auto shut off" ?? Or is this common on these big machines?? I looked thru all the settings, and did not see anything. Thanks in advance, Laser801"I'll be back"👍 1Comment
