MP C306 Firmware Update Issue
    • 37641
    #16
    Re: MP C306 Firmware Update Issue
    Originally posted by mido2020
    Thanks for your reply.I don't have application site app in my firmware. I tried richo firmware app using my pc but it didn't work . I tried to register for richo octopus but i have access denied. I googled it but still I can't find link to download it. So I asked for your help.
    You should be able to download the Ricoh Firmware Update Tool from this link. Please note, there is a different tool for JAVA Platform. MP C306ZSP/C306ZSPF/C406ZSPF Downloads | Ricoh Global
    • mido2020
      • May 2022
      • 18
      #17
      Thanks I already tried this tool but it didn't work. All i got was an update for Java. But my old firmware still the same.1f843385-2539-44d1-9923-565ad97eed31.jpg
        • 37641
        #18
        Thanks I already tried this tool but it didn't work. All i got was an update for Java. But my old firmware still the same.[ATTACH=CONFIG]53178[/ATTACH]
        Sounds like you only downloaded the JAVA Platform tool and not the main firmware tool. You might already be at the latest version.
        Exactly what is the problem that you think you need firmware to correct? You may beating your head against the wall over something that doesn't exist. Start a new thread with all the information that we need to diagnose your problem.
        • copier tech
          • 8235
          #19
          I wonder if anyone has the latest firmware for mp c306z . I really need to update my copier and i can't find it anywhere
          Happy to help, drop us an email.
          Printer & Copier Firmware - www.printerfirmware.co.uk
          • Gift
            • Mar 2011
            • 2459
            #20
            That's the FW version for the panel - kind of "not so important" - you can see more FW version infos on the web interface, perhaps copy&paste it here so we can tell you if an update makes sense. What's the reason you think you need an update?
            • mido2020
              • May 2022
              • 18
              #21
              Thanks for your help here is My device infos
              Module Name Version Part Number
              System/Copy 1.18.1 D1965400W
              Network Support 15.30 D1965792M
              Fax 09.00.00 D1965784K
              RemoteFax 05.00.00 D1965785F
              Scanner 01.22 D1965787P
              Web Support 1.13 D1965788L
              Web Uapl 1.03 D1965789C
              animation 2.03 D1965790D
              NetworkDocBox 1.07 D1965793J
              Printer 1.12 D1965794P
              RPCS 3.18.12 D2145795B
              Font EXP 1.00 D1475581
              PCL 1.06 D2145796F
              PCL Font 1.14 M1095273
              PS3 1.00 D2145797A
              PDF 1.02 D2145798B
              PS3 Font 1.11 D6415763A
              Java VM v12 std 12.27.03 D2145799E
              Data Erase Onb 1.00 D2025556
              GWFCU3.8-9(WW) 05.00.00 D2145786G
              PowerSaving Sys F.26 D1965782A
              NAND FLASH M0425E -------
              Engine 1.13:03 D1965775J
              Application Version
              Application Name Version Part Number (or Product ID) Status
              M2a_System 1.27.2 D2411425F -
              My interface is so old compared to a friend who has the same machine. I only have classical tools . I have no application site to download programs . I have no widgets to use. I guess it is old version of android. Sometimes my apps don't log on so I had to restart the machine.
              • Gift
                • Mar 2011
                • 2459
                #22
                This looks pretty up to date to me,
                here's the TXT from a package FW (12/2021):
                <<Package>>
                package_ALL [GRIC2CHa_pk]
                D1965406S Ver. 14.00 -> D1965406T Ver. 15.00
                <<Separate>>
                System/Copy [GRIC2a_system]
                D1965400S Ver. 1.15 -> D1965400W Ver. 1.18.1
                Fax [GRIC2a_fax]
                D1965784H Ver. 07.00.00 -> D1965784K Ver. 09.00.00
                RemoteFax [GRIC2a_fax2]
                D1965785E Ver. 04.00.00 -> D1965785F Ver. 05.00.00
                Scanner [GRIC2a_scn]
                D1965787L Ver. 01.19 -> D1965787P Ver. 01.22
                Web Support [GRIC2a_web]
                D1965788K Ver. 1.12 -> D1965788L Ver. 1.13
                Network Support [GRIC2a_net]
                D1965792J Ver. 15.27.1 -> D1965792M Ver. 15.30
                NetworkDocBox [GRIC2a_netfile]
                D1965793H Ver. 1.06 -> D1965793J Ver. 1.07
                Printer [GRIC2d_printer]
                D1965778N Ver. 1.11 -> D1965778P Ver. 1.12
                Printer [GRIC2e_printer]
                D1965794N Ver. 1.11 -> D1965794P Ver. 1.12
                PCL [GRIC2d_prt_PCL]
                D3AB5705D Ver. 1.04 -> D3AB5705E Ver. 1.05
                PCL [GRIC2e_prt_PCL]
                D2145796D Ver. 1.04 -> D2145796F Ver. 1.06
                M2a_System [M2a_System]
                D2411425B Ver. 1.25 -> D2411425F Ver. 1.27.2
                M2a_LegacyUI [M2a_LegacyUI]
                D2411427T Ver. 1.17 -> D2411427Y Ver. 1.21
                Application Site [M2a_zoo]
                D2411467J Ver. 1.05.01 -> D2411467K Ver. 1.05.02
                M2a_ScnFldrHlpr [M2a_ScnFldrHlpr]
                D1961448A Ver. 1.01 -> D1961448B Ver. 1.1.2
                M2a_ICCdDisptch [M2a_ICCdDisptch]
                D2411450C Ver. 2.12.06 -> -- Ver. --
                I think there's no way to get this machine showing the modern user tools - I think this was introduced with the later IMC series with a certain ACT level. It's also possible that your friend owns an MPC307 - it looks kind of the same but also comes with some design tweaks you won't get with an update.
                • mido2020
                  • May 2022
                  • 18
                  #23
                  I bought the two machines and I'm sure they are both mp c306z. Today I will visit him and get his Fw and his interface screeshots and post it to comapre .
                    • 37641
                    #24
                    I retired in the spring of 2017. The MP C306Z/406z were introduced while I was still working. When was the IMC series first introduced?
                      • 37641
                      #25
                      PCL 1.06 D2145796F
                      PS3 1.00 D2145797A
                      PDF 1.02 D2145798B
                      Application Version
                      You may have an original Normal Operation panel. If there is a physical 10 key number pad it is a normal panel. Have you tried scrolling the home screen? When the SOP was introduced many user did not like there being no ten key of the quick operation screens and had the classic tools installed on the main Home screen. You might be able to use the Smart Operation Panel Designer to further configure your screens. Put a request in the manual request forum if you need the Designer.
                      • copier tech
                        • 8235
                        #26
                        PCL 1.06 D2145796F
                        PS3 1.00 D2145797A
                        PDF 1.02 D2145798B
                        Application Version
                        This firmware is very old. For example System/Copy is Ver.1.29 dated 2022/04/16
                        • mido2020
                          • May 2022
                          • 18
                          #27
                          I guess it G2 SOP panel check the photo
                          • mido2020
                            • May 2022
                            • 18
                            #28
                            I believe there is something wrong with my firmware. Application Site app is missing . It isn't installed. How can I install it.
                            Is it possible to backup my friend Firmware and install it on my machine?
                            • copier tech
                              • 8235
                              #29
                              Contact us for the correct & latest firmware.
                                • 37641
                                #30
                                Have you tried the Ricoh Firmware Update Tool?
                                Go to the Ricoh Middle East support page. Support and downloads | Ricoh Middle East
                                Search MP C306. Select either of the results.
                                Click Drivers and Downloads, Click the link given, Click Firmware
