MP C306 Firmware Update Issue
  • mido2020
    • May 2022
    • 18
    #46
    Re: MP C306 Firmware Update Issue
    It is not allocated for Windows. The base OS for the MP C306 is not Windows. You need a software that can read and diagnose a raw drive without erasing anything already there.
    I formatted Hdd through sp code but how can I make sure that it is working properly
      • 37641
      #47
      If it wasn't working it would have coded during format.
      • copier tech
        • 8235
        #48
        Ok Thanks. But I spent last days googling for answers. I found some information which say that without hdd there is no way to use usb storage devices or upgrade firmware. When i checked my device storage It was only about 7 giga and I know that the machine supposed to have 320 giga hdd so I removed the cover with doubts that I have no hdd. I was suprised to find it exist. I remover it and connect it to pc to check if it ok or not but I recevied the message in the photo and it is unallocated what should I do.[ATTACH=CONFIG]53360[/ATTACH]
        This is not entirely true as you can update the firmware without the optional HDD installed.
        Simply update using an SD card.
