Rico Aficio MP-C2050 Does not detect paper in any tray
  • Spar
    • Jan 2019
    • 32
    Rioch Aficio MP C2050 does not detect paper in any tray even though the paper is in.
  • Popolopo
    • May 2023
    • 110
    Does the tray lift up? If no, check the motor and stuff that lift it up.
    If the tray rise, need to check the sensor
    • Spar
      • Jan 2019
      • 32
      I did not see any such action in this model
      • Popolopo
        • May 2023
        • 110
        My bad. This one doesn't use motor to lift the tray. Then, you need to the sensor above the paper
        • Spar
          • Jan 2019
          • 32
          It does not detect any one of the two trays, both sensors can not go bad. I must be a common problem to both trays.
            • 37055
            Check SP 5803-52 Tray 1 and SP 5803-53 Tray 2. They should be 0 when the tray in closed. If I remember correctly, the tray set switch is part of the paper size switch for each tray. Also Ricoh had a problem with tray latch mechanism causing the trays to not be held closed properly resulting in the tray not being detected as set.
            • Spar
              • Jan 2019
              • 32
              Thanks, I will check and get back to you,
              I had the problem of not latching the tray and getting this error, where is the tray latch sensor please?
                • 37055
                It is not a sensor. It is a plastic part of the tray that breaks off. You either have to replace the tray or see if the repair kit is still available. There was a bulletin on the repair kit.
                • Spar
                  • Jan 2019
                  • 32
                  It happened with me and I got them made using a 3D printer, that part is working now,
                  • luca72
                    • Oct 2017
                    • 1711
                    in that model the drawer lock systematically breaks, try pushing the drawer in with your knee, and see if the icon with the paper appear
                    • Spar
                      • Jan 2019
                      • 32
                      I tried it and it does not,
                      • luca72
                        • Oct 2017
                        • 1711
                        tear down both rear switch's, and check operation by multimeter, but two tray dont work...never happen to me, could be the IOB.
                        • Spar
                          • Jan 2019
                          • 32
                          If i put top tray to the button, it works, but it does not work when i move back it to the top.
                          • rthonpm
                            • Aug 2007
                            • 2847
                            Pull out the trays and make sure there's no wadded paper or other obstructions againt the machine frame.
                            • Spar
                              • Jan 2019
                              • 32
                              All is clear around the top tray,
                              Do you know where is the switch to detect the presence of the top tray?
