White Stuffs on Thick Card Ricoh mpc4502
  • luca72
    • Oct 2017
    • 1677
    Re: White Stuffs on Thick Card Ricoh mpc4502
    Originally posted by Pixtech Frameworks
    How do I change the driver settings Luca???
    1 - CLEAN WELL ALL TERMISTOR'S
    2 - use photo settings
    OH! ... please! ... let us know!
    • anothertech
      • 1756
      How does it look when you make a copy on that paper?
      • luca72
        • Oct 2017
        • 1677
        If you don't know the media gsm, how do you know if the media type is set correctly ... or even machine specifications?
        HI, blackcat4866, you have touched an interesting "button", on which I want to deepen, I usually go to nose, but if one wants to go as a sniper, I use a precision scale, which can be purchased from Chinese shops for 13 euros, you can weigh the sample sheet, and calculate the weight per square meter with some simple arithmetic multiplication
          • 22932
          #19
          Exactly correct.
          I have a precision gram scale to weigh a single sheet. If you only have a postal scale, you can weigh 20 sheets of your media in ounces, convert to grams, then divide by the 20 sheets.
          Once you know the numerical grams per page, divide by the fraction of 1 meter your page represents (A4 paper is 0.0625 meters).
          I think I have an attachment:
            • 36851
            #20
            I think that part of the problem is that most customers make settings for paper type, i.e. plain/recycled/letter head/card stock/etc, and don't about the thickness setting especially with card stock.
              • 22932
              #21
              Kyocera makes this especially confusing. There are 12 or so media labels, and 6 custom labels, each of which can be changed to whatever you like. When I get an Kyocera enduser that uses various medias (and there aren't very many endusers like this) I will set up the most commonly used media types in the Custom slots, and name them for the specific gsm ranges. In this way, it actually makes some logical sense, for a change.
              Konica Minolta does a much better job of specifying a gsm range for each media type. The spreadsheet helps present media types in a consistent way. =^..^=
              • luca72
                • Oct 2017
                • 1677
                #22
                I bet a beer, that if he cleans up the thermistors, and sets up the drivers like I told him ... he'll solve the problem .... that kind of setting, is the one I personally use, and it has worked loads of times!........ .if he doesn't let us know anything more, I'll pull his ears ... LOL
                • anothertech
                  • 1756
                  #23
                  He's got to narrow it down, does it show the problem when copying, or just when printing? If it's just when printing, he's got to change settings in the driver or change the machine to "machine settings".
                  • luca72
                    • Oct 2017
                    • 1677
                    #24
                    he talks about print ... now he will be in hibernation ... LOL ... he can't hear anymore
                    • Pixtech Frameworks
                      • May 2020
                      • 231
                      #25
                      Smiles.... Definitely, I'll come back here and share the testimony....
                        • May 2020
                        • 231
                        #26
                        I'll see to this..
