MPC3504 freezes at start up . .
  • GeorgeBest
    • Jul 2009
    • 526
    HI,
    Customer called for an MPC3504 that won't start, it freezes on blue screen, no SC code
    Switched the ctrl board, HDD and the Bicu from an workung machine, no results . .
    Operation Panel? (not changed yet)
    any suggestions?
    Thanks in advance
  • rthonpm
    • Aug 2007
    • 2854
    Op panel is a possibility. Checked that the device is getting clean power?
      • 37491
      Can you access WIM while the blue screen is displayed? If so. is there an error code displayed in WIM? If not, try powering it on with the front door open. If the problem is an engine error that is not being displayed, that will prevent the engine from starting until the door is closed. While the door is still open, enter SP mode and check the logged service codes for any codes that have not been displayed.
      • luca72
        • Oct 2017
        • 1779
        Originally posted by GeorgeBest
        HI,
        any suggestions?
        Thanks in advance
        In octopus, there Is a RTB that show also with photo, the precise work around flow to attempt to solve this, maybe also in last SM
        Now im at home, and havent access to octopus for take these RTB
        "I'll be back"
        • luca72
          • Oct 2017
          • 1779
          Ultra-likeπŸ‘πŸ‘πŸ‘
          "I'll be back"
          • GeorgeBest
            • Jul 2009
            • 526
            Operation panel it was . . .
            • luca72
              • Oct 2017
              • 1779
              It happens, in a couple of years I replaced 3 of them, luckily taken from retired machine, the panel cost its 2500 euro!
              "I'll be back"
              • copier tech
                • 8144
                You can usually recover the SOP by updating the cheetah OS. Or setting the SOP back to factory default.
                • Gift
                  • Mar 2011
                  • 2459
                  LOL yeah nothing beats a good collection of parts donators if you have a lot of units with service contracts in the field
