Paper wrinkle on left side
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Misc] Paper wrinkle on left side
    I prepare one MPC 3002 fusing unit (pressure roller, flim, oil pad, lampholder all new) but wrinkle comes. I don't know how to solve this problem. If anybody knows please help me on this.
    • 37532
    Re: Paper wrinkle on left side
    Are you sure the wrinkling is being caused by the fusing unit? More often than not it is something in the PTR section causing the paper to not enter the fusing unit correctly. The transfer case used with this model has a history of problems caused by plastic parts breaking. If the case has not been properly updated IAW BULLETIN NUMBER: D111/D142 – 021, you need to do so. If you put the newer style PTR in the old style case, you have introduced a misalignment. Yoou may also need to update the discharge plate in the paper transfer unit IAW BULLETIN NUMBER: D111/D142 – 022. Bulletins attached.
    rfg056662.pdf
    rfg056868.pdf
    • copier tech
      • 8172
      Did the wrinkle only happen after you worked on the fuser unit?
      • kanagavel
        Service Engineer
        • Feb 2020
        • 78
        [QUOTE=copier tech;1970448][B]
        Hi sir, thank you for your reply.
        Yes the wrinkle happened after i worked on the fuser.
        Actually why i did this fusing unit because the fusing flim torn so i change the flim together i change pressure roller also.
        So now i don't know how to solve this wrinkle problem.
        I try to upload the pics of wrinkle problem here but i couldn't.
        • copier tech
          • 8172
          [QUOTE=kanagavel;1974412]
          [B]
          Sounds like the pressure roller bearing is not it the correct position.
          Did you replace a genuine Ricoh fuser sleeve unit or compatible ?
          • kanagavel
            Service Engineer
            • Feb 2020
            • 78
            [QUOTE=copier tech;1975054]
            Hi sir, i used compatible fusing sleeve and pressure roller also not original.
            Sir one more thing I want to know can you please help me, is there any procedure or correct way or easy way to adjust the fusing pressure by manually because there got 2 springs for pressure adjustment can i try the adjustment for this wrinkle problem.
              • 37532
              [QUOTE=kanagavel;1975178]
              Unless one or both of the springs are old and loosing their compression force there is nothing about the springs to cause wrinkling. If you really think it is the springs, then order two new springs from Ricoh. Do not use after market parts as the quality and consistency is not guaranteed. The same is true of the sleeve unit and the pressure roller. A warped sleeve frame will cause wrinkling. A non original pressure that is even the slightest different from one end to the other will cause wrinkling.
              • kanagavel
                Service Engineer
                • Feb 2020
                • 78
                [ATTACH]50779[/ATTACH]
                [ATTACH]50780[/ATTACH]
                Hi sir, thank you for your response. I think wrinkle problem because of the fusing unit. Because i use the other fusing unit in the same machine no wrinkle problem comes. When i use the fusing unit that prepared by me the wrinkle problem coming.
                  • 37532
                  Then order Genuine Ricoh either complete fusing unit or sleeve and pressure roller.
                    • 30294
                    measure the distance of the screw to nut on the good unit.
                    Than adjust the one thats having the problem as close as you can.
                      If you bought a complete unit, I would contact the folks that put it together.
                      If you did, a good learning lesson.
                        • 37532
                        What screw to what nut? There is no adjustment. When you don't know the model and have never work on them, don't make a fool of yourself. At the least you should check such things as the service manual and parts catalog before you post.
                        • GIUBOSS
                          • 1436
                          Damp paper?
                          • mikadonovan
                            • May 2008
                            • 2931
                            Since it only happened after you worked on it, just go ahead and disassemble it again. Reassemble paying attention to the details. We all have had to do this at one time or another, and you will likely discover what the malfunction is.
                            NEVER ASSUME ANYTHING
