M2701 toner empty
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    M2701 toner empty
    The device is almost new. Model M2701. The user says that the printer reports that the toner is empty even though he tried two new ones. I will check if he is dosing the toner to the developer. Can anyone tell me how to start toner dosing? Thanks.
    Canon tech Z
  • GIUBOSS
    • 1385
    Re: M2701 toner empty
    check if the semi-transparent valve located under the black cap is not trapped in the hopper. Check as you have already mentioned if the toner falls into the pcdu.
    • csliao
      • Oct 2021
      • 33
      Originally posted by zoraldinho
      嗨,
      該設備幾乎是新型號的M2701。用戶說,儘管他試用了兩個新的,賣家還在報告墨粉已空。我會檢查他是否給 添加了碳添加劑粉。誰能告訴我如何開始碳粉劑量?謝謝。
      佳能技術Z
      Giới Thiệu May Ricoh M2701 - YouTube
      拆箱機 RICOH M 2701 多功能複印打印 - YouTube
      1:25
      • dalewb74
        • Feb 2018
        • 1126
        well if it's almost new then it probably only has a starter cartridge in it....
        • luca72
          • Oct 2017
          • 1747
          Canon tech Z
          try to open/close the low right low door, or remove and re-enter the pcdu to reload toner routine, and reset a condition, maybe clogged toner patch by cool temperature and need a vac(?)
          "I'll be back"
