SC899 and SC990 in IM C2000 whithout lan connected
  • levillageinformatique
    • May 2025
    • 18
    Hello,
    I'ts the first time I have this problem,
    SC899 and SC990
    Ethernet is not connected !!!
    the machine is ready, when I want make a copy or print counter, the machine don't start after few minutes I have this message.
    I can scan it's ok
    ✅ I format hard drive
    ✅ I change hard drive
    ✅ I update firmwares
    ✅ I disconnect and reconnect memory (2 Go DDR3)
    I don't know the issue
    When I power on the machine I don't hear any motor, I don't have time to test yesterday, maybe problem with polygonal motor/laser unit ?
    I don't know if the controler board have problem
    If someone have an idea ....
    Great regards
    • 37488
    SC899 could be corrupted firmware or defective RAM.
    SC990 might be a performance error.
    Firmware update won't replace corrupted firmware if it is at the current version. You have to use individual modules and overwrite the existing firmware.
    Reseating memory DIMM will not repair bad memory. It needs to be replaced with NEW.
    • Popolopo
      • May 2023
      • 133
      try check nvram. make sure all leg insert correctly. if all good, most probably firmware.
      also check drum, where it got torn apart or not.
      • luca72
        • Oct 2017
        • 1778
        Originally posted by levillageinformatique
        Hello,
        SC899 and SC990
        I can scan it's ok
        Great regards
        try to save smc information by sp824-upload sd card, perform engine reset sp801-engine, and the others, reboot the machine, run sp824-download sd card
        p.s. try also if the hdd harness its upgraded, must be present a stamp in one of two side of connector, its good idea replace it
        "I'll be back"
          • May 2025
          • 18
          thank you for comment, I know, it's the last thing I will do, I order memory (2 Go so dimm), I will test with new memory and re-init the machine if it don't works
          regards
          • luca72
            • Oct 2017
            • 1778
            regards
            well, let us know when you resolved
            "I'll be back"
            • Daniel_B81
              • Jan 2019
              • 43
              This error might be a firmware issue, they mentioned this on a support group meeting today and the solution is to downgrade the firmware, although they mentioned that it should only affect IM C4500 and aboce but lower models could be affected if they're upgraded through ARMS.
              • copier tech
                • 8144
                Hello,
                SC899 and SC990
                I can scan it's ok
                Great regards
                Which FW version did you upgrade to?
                Sounds like a CTRL board has failed.
                • CopyBats
                  • Aug 2011
                  • 146
                  Turn off auto reboot sc 5875-001
                  under 5801 reset all the applications. Do not touch engine clear.
                  Printer application, copier application, NCS etc.
                  Turn off machine. Unplug machine from power cord, press power button to discharge machine and then plug cable and turn machine on after 5 mins.
                  If it works, don't touch it.
                    • 37488
                    After clearing NCS, you will have to reenter all network settings.
                    • CopyBats
                      • Aug 2011
                      • 146
                      Sometimes a necessary evil. In Multi user environment, I have changed IP address because there are so many users, especially mobile users. I also disable airprint and let customer know to use at your own risk. 20-50+ User environment people don't need airprint. Especially when guests connect to their network too and print random stuff ( not to mention security agents, cleaners etc).
                      Also have people with WSD drivers with print jobs in their que who come back to office after a few days and as soon as they connect to the network, computer tries to resend the job.
                        • May 2025
                        • 18
                        Yes, sometimes there is problems, especially with Windows 11 some months ago, sometimes we must disable some protocols
                          • May 2025
                          • 18
                          Hello, I resolve the problem,
                          I think it's a bad automatic firmwares update
                          There was a problem with 8.03 package and now with 8.04
                          The only solution is to clear engine (5.801) and reinstall all
                          I'm looking how to desactive automatic firmwares, if someone have an idea for next time ;-)
                          Thank you a lot
                          • copier tech
                            • 8144
                            The error occurs while the device is not connected to any network / offline.
                            • luca72
                              • Oct 2017
                              • 1778
                              Thank you a lot
                              well, I told you, that electronics is very sophisticated, it even goes haywire on its own
                              "I'll be back"
