Hello,
My Ricoh MPC4503 shows the following message:
I saw there's already a topic related to this issue:
https://www.copytechnet.com/forum/te...icoh-mp-c-5503
My question is whether this error could be caused by unstable or low voltage in the power supply.
The machine is located in an area where voltage sometimes drops below normal. I don’t have a way to fix the electricity problem at the moment, so I would like to know if this error could be related to that, or if it's likely caused by something else.
If it's power-related, then I’ll stop looking for other solutions for now. But if not, I’ll keep troubleshooting.
Thank you very much!
Functional problems detected.
Press restart after the current process.
Repeat settings after machine has restarted.
