Ricoh im c6000 - loud noise near fuser unit
  • EzSkeez
    • Jun 2023
    • 10
    [Noise] Ricoh im c6000 - loud noise near fuser unit
    I am having trouble figuring out the cause of this noise that occurs intermittently. I have replaced the ITB Unit, Fuser unit, and PCDU:K due to PM.
    After replacement noise is still occurring. No error codes and machine is working fine, but this noise is painful.
    Has anyone come across this issue before?
    Thank you
    • 8131
    I would start by running output checks in SP mode to help narrow down the issue.
    Run each motor until you hear the noise, from there check the service manual to find out what unit that motor runs.
    • luca72
      • Oct 2017
      • 1732
      Originally posted by EzSkeez
      Thank you
      Check this.
      • luca72
        • Oct 2017
        • 1732
        Thank you
        Check this.
        if you want test sp-804 with the fuser unit, remember of put out side the waste toner bottle from machine, otherwise you destroy the sleeve unit
        • Polo-022
          • Sep 2007
          • 484
          What kind of noise is this? Is it a squeaking, a moaning , a rattling or chattering noise...service manual helps you to describe it, at least!
          • EzSkeez
            • Jun 2023
            • 10
            Polo-022 If you click on the google thumbnail and request access I'll be able to allow you to see the video. I would see moaning noise.
            • EzSkeez
              • Jun 2023
              • 10
              copier tech I have run output checks and the noise does not occur.
              luca72 Thanks for the RTB. I did see that, but I have a brand new fuser unit part no.D0BQ4025 and the noise is the same.
                • 37240
                Check the exit section. I have had the heat from the fusing unit boil the oil out of the cintered bushings and build up a lacquer film on the shaft. Initial symptom is noise. Eventually it will seize and cause jamming.
                • luca72
                  • Oct 2017
                  • 1732
                  the link doesn't work, can you upload it to youtube?
                  • EzSkeez
                    • Jun 2023
                    • 10
                    luca72 https://youtube.com/shorts/wSoaE_hvrbA?feature=share
                    • EzSkeez
                      • Jun 2023
                      • 10
                      luca72 https://youtube.com/shorts/qoDUpo4bhGQ?feature=share
                      • EzSkeez
                        • Jun 2023
                        • 10
                        luca72 https://youtube.com/shorts/o6gqAiMukGA?feature=share
                        • Popolopo
                          • May 2023
                          • 113
                          based on the sound. i suspect gearbox for fusing. can service it, lubricate the shaft with grease.
                          when you remove it, manually spin the fusing motor, to check whether it make similar noise.
                          • luca72
                            • Oct 2017
                            • 1732
                            azzz...I've heard it before, it's happened to me before, I just don't remember, I called it "camel fart" I have to dig into my memory, so the fuser is new, and it did it before too, did I understand correctly?
                            try anyway to free run the fuser unit with sp804-fuser, remember first of put off of the side the waste toner bottle for not activate the lamp
                            • luca72
                              • Oct 2017
                              • 1732
                              listening to it better several times, the first 2-3 seconds, you can hear a change in the sound, which seems to be the activation of the pressure mechanism, it could be the mechanism of the pressure release/insertion of the fuser, in particular the motor unit, you can also activate only that in the sp804
                              try to check also this RTB
