Vertical scratches on the ITB PRO C5200s
  • Marwan
    • Oct 2023
    • 31
    Greetings for all,
    I'm facing a vertical scratches on the Image Transfer Belt ,Please find the attachment,
    wondering how to prevent it or at least from what it comes up.
    Best regards
  • GIUBOSS
    • 1437
    Print quality? Replace the cleaning unit (and not only) at the end of its life according to the PM counter, do not use cheap / recycled paper ...
      • 37555
      Originally posted by Marwan
      Greetings for all,
      Best regards
      Horizontal and vertical refer to the ways a picture can be hung on the wall! Are the scratches in the direction of paper travel or perpendicular to the direction?
      • dalewb74
        • Feb 2018
        • 1162
        was the belt recently replaced? looks like it wasn't in the proper position. and was raised a bit when it was slid back into the copier. which could lead to it getting scratched. then again it could have been the customer messing with it as well.
        • anothertech
          • 1771
          Was the black PCDU removed when the transfer roller handle was still up?
          • GIUBOSS
            • 1437
            These are scratches and marks caused by the user or by incorrect assembly or disassembly of the parts around it.
            • Marwan
              • Oct 2023
              • 31
              no sir,all disassembly was according to the service manual
              • Marwan
                • Oct 2023
                • 31
                how would it be from the user?and abount the re-assembly please aware that i went step by step with the service manual,however i think it comes when i pull the pcdu out and insert it back perhaps that was the issue but i don't have a prove or at least can't see what happens inside
                • Marwan
                  • Oct 2023
                  • 31
                  i did,with orginal ones,but i noticed it occured with all same series,that what getting me nuts
                  • Marwan
                    • Oct 2023
                    • 31
                    the scratches is cross feed,if the page hanged on wall you will find the scratches fro up to bottom
                    • GIUBOSS
                      • 1437
                      Well I think that anyone who has experienced the user putting his hand inside the machines either to clean with paper or rags thinking of solving problems of dirt on the copies or to remove jammed paper with unsuitable objects
                      • Onion_wizard
                        • Jun 2025
                        • 10
                        Line up those marks with the PCDU's, this can also happen by sliding the transfer belt unit in and out over a period of time, it slides slightly against the PCDU's, so if the marks line up with your PCDU's then that is the problem.
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 195
                          They are obviously lines caused by criminal hands
