Ricoh Pro C7100 Error Code SC202-01
  • svampekongen
    • Jun 2025
    • 12
    [Error Code] Ricoh Pro C7100 Error Code SC202-01
    Hi everyone,
    We recently purchased a used Ricoh Pro C7100, and I’ve just finished assembling it. However, when I power it on, I’m getting the following error: SC202-01.
    From what I can gather in the manual, this refers to:
    SC202-01 – Polygon Motor: ON Timeout Error (Bk)
    I would really appreciate it if anyone could help me understand what might be causing this or point me in the right direction. Thanks in advance for any advice or suggestions!
    Best regards,
    Sebastian Markussen
  • davel
    • Oct 2011
    • 1108
    Replace the motor
    • anothertech
      • 1771
      Check fuse FU3 on PSU2. If it's ok, check the fuses on each power supply.
      • svampekongen
        • Jun 2025
        • 12
        Originally posted by davel
        Replace the motor
        Hi Davel,
        Thanks for the suggestion. I’ve been looking through the manual, and from what I can see, it’s number 12 that needs to be replaced — is that correct?
        If so, I can't quite figure out from the manual the best way to access the motor. Is it from the front of the printer or the back?
        • svampekongen
          • Jun 2025
          • 12
          Hi anothertech,
          Yesterday I tried to replace the FU3 fuse, but had no luck. I'll try going through the other fuses as well. Thanks!
          • anothertech
            • 1771
            Try swapping the mirror motor with one of the other mirror motors, if they are the same part number. Got to go down through the top to get at them.
            • svampekongen
              • Jun 2025
              • 12
              Hi anothertech,
              Just to be sure it's these ones here right?
              • svampekongen
                • Jun 2025
                • 12
                Here is another picture that's probably better 😊
                • anothertech
                  • 1771
                  Yes, that's it.
                  • svampekongen
                    • Jun 2025
                    • 12
                    Yes, that's it.
                    Thanks a lot i ordered a new motor i will let you know how it goes. 😊
                    • anothertech
                      • 1771
                      Hey, I thought you were going to swap it with the other one to troubleshoot?
                      • svampekongen
                        • Jun 2025
                        • 12
                        Hi Anothertech,
                        Since I had to disassemble the entire color station to get to it, I thought: why not just buy a new motor instead of swapping them, rebuilding it, and then disassembling everything again? Hopefully, the new motor will do the trick. And if not, I figured—since it wasn’t that expensive—it wouldn’t hurt to have a spare motor lying around.
                        Hope that makes sense! I really appreciate your help and guidance with all this. Thanks again for taking the time to assist me.
                        • svampekongen
                          • Jun 2025
                          • 12
                          [QUOTE=anothertech;n1622873]
                          Hi Anothertech,
                          Thanks again for your help. I received the new motor and swapped it in, but unfortunately, the error is still there.
                          Do you have any other ideas on what I could try to help pinpoint the issue?
                          • anothertech
                            • 1771
                            Check output of PSU2. Also check connections from IPU to laser.
                            • svampekongen
                              • Jun 2025
                              • 12
                              Hi Anothertech,
                              Thanks so much! I went through the PTOP manual and saw how the polygon motor should be connected. I also noticed that the CN556 connector is for the polygon motor, and to my surprise, it was completely unplugged from the IPU. I'm not sure how or why that happened.
                              Now, however, I'm facing a new issue: I'm getting paper jams. The paper doesn't seem to feed through properly, and I keep getting a jam error. When I open the right drawer, the paper just lies there completely loose. I tried blowing dust off all the sensors, but it doesn’t seem to help.
                              It almost feels like the paper isn’t being gripped correctly—maybe due to a sensor issue or a motor problem? I'm not sure. Occasionally I also get an error related to the shift roller motor (SC586-21), and other times it's the registration timing motor (SC586-20). But when I restart the machine, the error disappears.
                              Do you have any ideas what could be causing this behavior? Or would it be better if I created a new post for this separate issue?
                              Thanks again for your help!
