Ricoh IM 350 ticking noise while printing, does not sound like the fuser
  • patterson70
    • May 2010
    • 601
    I can't narrow down the sound, it is a fast ticking sound only while printing. Machine only has 10K on it. Anyone seen this before?
  • anothertech
    • 1771
    Re: Ricoh IM 350 ticking noise while printing, does not sound like the fuser
    I have heard of it, good chance the noise is coming from the drum.
      • 8228
      ... hopefully the copier does not have a bomb inside it!
      • patterson70
        • May 2010
        • 601
        Ok, thanks, I will swap in another one when I get one and see. I was thinking it might be that...
        • patterson70
          • May 2010
          • 601
          Boom!
          • Gift
            • Mar 2011
            • 2459
            small printers = table fireworks
            • patterson70
              • May 2010
              • 601
              It is the drum unit, I swapped in a used up one and no ticking.
              The drum unit only has 10K on it out of a 70K yield. So, if anyone knows what the drum unit is the cause please let me know. If it has happened to me it probably will happen to someone else down the road...
              Thanks again!
              • patterson70
                • May 2010
                • 601
                I think I know what it is. The machine when it was ticking had a P501 Drum in it. Not sure who put it in there, I inherited the machine.
                The drum that the IM 350 calls for is the D0A4-2021, which costs twice as much. But it does not tick.
                So, something about the P501 causes the tick but it works, so not sure what it could be. It is irritating to a customer so the P501 is not a good solution to saving $75. Unless it can be modified.
                I am going to test with another P501 when I get one to double check.
                Then if it ticks i will know for sure. Then will try to see why. They look identical in every way. Might be internal.
                • luca72
                  • Oct 2017
                  • 1784
                  Maybe the drum have a noisely agitator inside(?)
                  "I'll be back"
                  • patterson70
                    • May 2010
                    • 601
                    Hey I purchased another brand new P501 Drum and it ticks as well. I put the D0A4-2021 Ricoh Drum back in and no ticking. The P501 Drum says on the box it is for the IM 350. Maybe a bad batch of P501s?
                    This is causing me a huge inconvenience!
                    No one else has seen this?
                    • redneckstylin
                      • Sep 2011
                      • 173
                      I tend to stay away from these as they are brutal with skewed scanning. I will ask the guys tomorrow about ticking with the handful we have in the field.
                      • patterson70
                        • May 2010
                        • 601
                        Great thanks. Checking to see if you heard anything?
                        also could you tell me what you do to resolve the skewing?
