Drum damaged by developer on Ricoh MP5500/6001/7000/7500 etc series
  • General Copiers
    • Feb 2020
    • 27
    [Misc] Drum damaged by developer on Ricoh MP5500/6001/7000/7500 etc series
    Hi guys, we have a lot of Ricoh MP5500/6001/7000/7500 series.
    Sometimes they have this problem:
    The amount of developer inside the development unit decreases and it's attracted to the drum.
    A large quantity of developer also accumulates under the cleaning blade, causing damage to the drum.
    Has this happened to any of you? How can it be fixed?
    Thank you very much
  • luca72
    • Oct 2017
    • 1677
    Re: Drum damaged by developer on Ricoh MP5500/6001/7000/7500 etc series
    Thank you very much
    how many prints does the machine have? when was the developer last changed? or the opc kit?
    • General Copiers
      • Feb 2020
      • 27
      On the last machine that had the problem, an MP5500, we changed the drum, cleaning blade and developer on 15 February.
      Then the problem happened and on the 23rd we had to put a new developer, after 18,000 pages.
      This MP5500 has a total of 3,650,000.
      We only use original toner and developer. The problem occurs with both original or oem drums and cleaning blades.
      • luca72
        • Oct 2017
        • 1677
        ok .... 3650k is a lot, I think the development group is a walking dead, the magnetic roller in particular.
        however put it on the table and you turn the knob with your hands, and check how it behaves at the sealing level, and that there are no leaks from the rear sealing bush where there is the magnetic roller gear
        • MIKON
          • Jul 2015
          • 184
          sounds like you need a new developer unit I had several with over 10 mil on them
            • 36832
            With those all being older models, you most likely have excessively worn shaft seals. They probably also have had problems with developer/toner getting on the first feed module. In fact I have a feeling that you have already had to replace one-way gears on the feed module as a result of paper jamming.
            • rthonpm
              • Aug 2007
              • 2847
              Without fail, I'd replace the developer unit on these every 1-1.5 million pages as beyond that I'd start to have developer seeping into the feed stations. My profile pic is from an old 2075 that I had to rebuild the feed stations on the first two trays thanks to developer contamination.
              • luca72
                • Oct 2017
                • 1677
                True! After 800k prints,
                this problem can occur, I have found that it happens from model 9000 upwards, perhaps the material of the bushings yields as the speed of the machine increases (?)
                Infact, i put a cover over the station zone, with a short strip of magnetic adesive cuttable, that catch and keep the falled developer, and protect the espensive martini pick up station.
                • emiliorsg
                  • Jul 2018
                  • 141
                  [ATTACH=CONFIG]52296[/ATTACH] [ATTACH=CONFIG]52296[/ATTACH] [ATTACH=CONFIG]52297[/ATTACH]
                  I think all do it too.
                  I would try to change the seals of the PCU and the cleaning brush.
                  • Gift
                    • Mar 2011
                    • 2444
                    Another Luca Mod, very nice^^ We're going to test your jogger roller mod tomorrow with a SR3210 btw
                    • Codex
                      • May 2008
                      • 694
                      we had the same problem years ago, and we did exact the same!!
                      Memento Audere Semper
                      • satins
                        • Feb 2021
                        • 89
                        It will be a good option to replace the development module and
                        you could also look to replace the LED array that sits on top of drum in the drum unit.
                        B234 2270 LED Array
                        • orestesp
                          • Sep 2019
                          • 221
                          Sorry to "hijack" the thread, so to speak, but what parts that can be ordered from Ricoh do you guys, from experience, replace preventatively in order to keep the developing unit functioning for as long as possible and prevent the spillage of developer everywhere?
                          I have heard that the all 4 x 8mm bushings should be replaced every other developer change (assuming they are done at 350-400k), is there anything else?
                          • satins
                            • Feb 2021
                            • 89
                            If you are using the genuine toner,you may not need to change the bushings or anything else.
                            However, if you use Compatible toner you may need to replace the developer agitator bushing every 200k-400k cycle and the worst case scenario can have a spillover effect on the paper registration and feeding unit down below.
                            So, be careful with the compatible toner!
                              • 36832
                              Maybe that is why I never had to replace bushings or anything else even though I had machines go over 5M before being traded in. And continue to work at another placement. Always used Genuine Ricoh and always did PMs within 5 % over recommended. Now the conductive bearing in the drum shaft holder were another thing. Replaced a couple of holders until some one posted the part number for the bearing here on CTN.
