mp 3351 changing developer in pcu unit
  • alvin_3000e
    • Dec 2008
    • 31
    Hi I replaced new developer in mp 3351 copier pcu unit using ricoh developer 28. When testing the printout I found a lots of small dots on the background of the print copies.
    Deleoper 28 is for that model of pcu. Is there any setting I need to do to removed the small dark dots on the background of the printed copies.
    • 37491
    What is the PM count for the PCU? Those look to me like drum spots. They start to appear when the drum is 15K or more beyond recommended replacement count. Replace drum, cleaning blade. charge roller and charge cleaning roller. Anything else will only make the spots worse.
    • Codex
      • May 2008
      • 704
      Ciao
      Hai cambiato solo sviluppatore o Pcu, blade ecc ecc. Hai eseguito l'inizializzazione?
      Memento Audere Semper
      • alvin_3000e
        • Dec 2008
        • 31
        The developer is new, drum and cleaning blade also new. I try developer mixing and initialising developer in sp mode still the same.
        • Codex
          • May 2008
          • 704
          Did you clean the mag roller? and changed also the trasfer roller unit?
          • MIGUELMARCHENA
            • Feb 2018
            • 195
            I have seen that when two types of developers are mixed, it comes out like this, or the cylinder and charge are very pitted.
            • alvin_3000e
              • Dec 2008
              • 31
              I think the problem is with the developer, previously I have replaced pcu developer before without any issues. This is the first time I encounter this problem. Thanks for all the advise given. Really appreciate for the feedback.
              • Luism
                • Dec 2024
                • 27
                Hello, those points are the contaminated developer, if it were the cylinder you would have a pattern of points that are repeated two or thirteen is in the copy, replace the developer again (it can be type 24 or 21, keeping 345 gr of weight) and then make SP 2801, remember to completely empty the unit of development and vacuum everything
                • Popolopo
                  • May 2023
                  • 134
                  it can be developer contaminated, or the toner is causing the issue.
                  • luca72
                    • Oct 2017
                    • 1780
                    It's called "rain effect" you have to replace the transfer roller, unfortunately no longer available here in Italy, you have to find a used but good one from another similar machine
                    "I'll be back"
