MP 2055/2555/3055/3555/4055/5055/6055 firmware needs
  • mindhunter
    • May 2008
    • 152
    Hi fellow technicians ,
    I am technician who lives in Toronto but sadly i dont have access to tsrc website to download 5series firmware.
    Does anybody can help with this matter?
    Thank you in andvance.
  • ccchuah
    • Mar 2009
    • 158
    Can use RFUT to update your firmware online
    • dalewb74
      • Feb 2018
      • 1167
      reach out to ricoh so they can get you access to the tsrc website? plus use the tool
        • 8198
        Happy to help. Drop us an email
        www.printerfirmware.co.uk
        • sandmanmac
          • 3987
          Lots of options......Run a manual update in SP mode, OR set machines to auto update in SP mode, or, yes, use the FREE tool as suggested.
          No TSRC access required
          • mindhunter
            • May 2008
            • 152
            But I want to change nvram.because the m1 is corrupted. Is it possible using sp mode? If yes, please somebody gives me an instruction.
            • sandmanmac
              • 3987
              That's not an NV Ram issue, and I don't understand why you think f/w will help.
              this code has been covered in countless threads on here and I don't believe firmware has ever resolved it.
              It's almost assuredly a failed controller.
              I Had this exact SC on this exact model just 2 weeks ago
                • 37585
                The service manual has an entire section on troubleshooting Sc672. Firmware will not repair a defective controller board.
                  • 8198
                  Try a firmware update via SD card if the update doesn't start you will have to replace the controller board.
                  We can supply the fw if you wanted to give this a try.
                  • mindhunter
                    • May 2008
                    • 152
                    So what should i do?
                    • mindhunter
                      • May 2008
                      • 152
                      Fyi my idiot colleague inserted m1 ic backward. So it heats a lot and im sure it is defected. And after this procedure this code has been appeared
                      • sandmanmac
                        • 3987
                        You should Re-read the last 2 sentences of my post that you quoted, The last sentence of Slimslob's, and the first sentence of copier tech's, and I think you'll have a pretty clear idea.
                        • Popolopo
                          • May 2023
                          • 141
                          If you say that, just change the nvram to a new one.
