How to scan ID card on MP C3003
  • menosmola
    • Apr 2014
    • 95
    Hi, an easy and old question, is it possible to scan both sides of an id card on a single page with an mp c3003?
    Thank you.
  • luca72
    • Oct 2017
    • 1724
    Re: How to scan ID card on MP C3003
    Thank you.
    Copia carta ID
      • 37168
      The entire setup sequence can be saved to a program key. After just 2 keystrokes and you are setup again. We had it as part of the initial setup of all machines being delivered to medical offices.
      • menosmola
        • Apr 2014
        • 95
        Thanks, but the copy mode is not a problem, the problem is the SCAN mode
        • Brianneoe
          • May 2015
          • 318
          You can program it in the same way as Slim stated in the scan mode.
          • menosmola
            • Apr 2014
            • 95
            In copy mode, i use 4 in 1 and 100% scale, but for scan Mode, those options are not available
            Enviado desde mi Redmi Note 8 Pro mediante Tapatalk
            • menosmola
              • Apr 2014
              • 95
              I think you have not understood me, what I want is to SCAN (not copy) the two sides of an ID to a folder and that a single-sided file arrives on the PC.
              • NakyJamelo
                Banned User
                • Feb 2023
                • 1
                It's great to hear you're interested in scanning ID cards with your MP C3003. To answer your question, yes, it is possible to scan both sides of an ID card on a single page with the MP C3003. Many multi-function printers like the MP C3003 have a duplex scanning option, allowing you to scan both sides of a document on a single page. If you're looking for a more eco-friendly and efficient solution, consider using an automatic document scanning and OCR app Smart Engines. They offer a variety of tools to help you quickly digitize and organize your ID cards, so you don't have to manually flip the cards over to scan both sides.
                • GIUBOSS
                  • 1385
                  I too would be interested in the subject, even if it is a bit outdated... However, it is not clear to me how you can not manually rotate the ID document.
                    • 37168
                    Real big possible with that, most ID cards are too small to be fed through a document feeder without jamming and possibly damaging the card.
                    • menosmola
                      • Apr 2014
                      • 95
                      Thank you.
                      The answer is simple, it is impossible to scan both sides of an ID card and for a single file to reach the PC on an MP C3003, you would have to use some type of editing program after scanning both sides separately or have an specific APP installed in the machine to do that function. It is a fact. From 3004 onwards it can be done....
                        • 37168
                        Actually that is wrong. I have been setting it up on Ricoh copiers at doctor offices for years, long before the C3003. Any digital copier that has duplex and combine functionality can do it. luca72 posted a link to the procedure in Italian. Here it is in English.
                        ID Card Copy
