ricoh mp402 , error 992-00
  • tullio
    • Feb 2012
    • 268
    hi, i have a ricoh mp402 problem, sc992-00 error. i have done all the updates but i have the same problem. Has anyone had a problem like this? thank you very much. sorry for not perfect english.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh mp402 , error 992-00
    Usefully enough SC992 is an "Undefined" SC code. It could be anything. Was anything done to the machine before it threw this code?
    Hit it.
    • tullio
      • Feb 2012
      • 268
      update of all firmware - hdd format. Same problem.
      • copier tech
        • 8174
        [ATTACH=CONFIG]52589[/ATTACH]
        Does the error occur with the LAN cable unplugged?
        Did you update ALL the firmware files? There's a bulletin regarding this make sure the power saving firmware is Ver.F.L3.06.2
        • tullio
          • Feb 2012
          • 268
          lan cable connected yes
          • luca72
            • Oct 2017
            • 1784
            "software error - undefinite error"
            backup address book via wim, export mc data on sd card, and try a well sp801 (full) and restart, if you dont notice of strange effect, leave it like this, the import of sd data could maybe transport again the software bug error(?)
            "I'll be back"
            • Gift
              • Mar 2011
              • 2459
              Well then disconnect it and restart the MFP - can't really recall any SC992 in combination with a bad job but you should check it.
              • tullio
                • Feb 2012
                • 268
                Ok.
                  • 37533
                  When you updated firmware did you use package firmware? In the past, package only replaced modules that were not current version. It did not replace corrupted modules because it had no way of know the module was corrupted.
                  • anothertech
                    • 1771
                    Yes they need to use the SD card method and OVERWRITE all firmware files. Next I'd reseat the ram dimms. Turn off java SP5730 to 0. Last, if you have the birth certificate, you could clear nvram and reinput the settings manually.
                    If all that does not help, you may be looking at replacing the controller pcb.
