Ricoh MPC 3004 SC 899-00
  • Ahmed Bushara
    • Mar 2015
    • 26
    [Error Code] Ricoh MPC 3004 SC 899-00
    Dear all
    I have this error, may I have your help I think it is software problem but I don't have firmware
    Thanks Awaiting for your kind response
    Thanks and best regards
    Ahmed Bushara
    Electronic Engineering technician
    Mobile: +249-999198804 /+249-123198804
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh MPC 3004 SC 899-00
    that's a print job problem in 99% - check if the MFP is functional without network connection, next step is testing with your laptop + direct connection.
    Some of the ususal causes: WSD port usage / crappy class drivers / browser printing......
    • anothertech
      • 1771
      Firmware update should help. Type in "ricoh firmware update tool" into google. Download and run the software. It's free and easy.
      • Debs1964
        • Oct 2010
        • 1693
        A firmware update may help, but switch the device off, disconnect from the network, power back on, does it come ready? Can you copy?
        Now switch it off again, reconnect it to the network, open all the paper trays, and power back on, if it's a print job that the device cannot print (corrupt job, or printing direct from a web browser), you should be able to delete the job(s).
        If that doesn't work, check the print driver(s), a recent Windows update decided to change the drivers to Microsoft IPP Class drivers, on an IPP port. Change it to the correct Ricoh driver, on a standard TCP/IP port
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • luca72
          • Oct 2017
          • 1784
          as Debs1964 suggested, I would also add in tools user> printer setting> auto delete job with error = on
          n.b. may need to go around pc, to manually delete print jobs, customers when they see it doesn't print, they keep insisting ... LOL
          "I'll be back"
            • 37532
            I would also add that before deleting the job see if you can identify the computer that it is coming from and that type of job it is. I frequently found it was someone trying to print from a website such as an online betting site or fantasy sports site.
            • copier tech
              • 8174
              Originally posted by Ahmed Bushara
              Dear all
              There are a few ways you can approach the SC899 error as other have stated.
              My method is to first unplug the LAN cable, turn on DHCP then plug the LAN cable back in to allow the device to obtain a new IP address.
              When it comes to ready with no error update ALL the firmware files (not just the package)
              Once the updates have completed set the original IP address back the device should then print out the job(s) causing the issue.
              • luca72
                • Oct 2017
                • 1784
                My apologize....but if the PC spool dont flush, or delete the job, when the PC repoint the mc online, the corruptes data dont re-crash the controller?
                "I'll be back"
                • davidmtupper
                  • Jul 2021
                  • 326
                  Originally posted by luca72
                  My apologize....but if the PC spool dont flush, or delete the job, when the PC repoimt the mc online, the corruptes data dont re-crash the controller?
                  The latest firmware can compensate for some, but not all, bad print jobs. If it allows the user to print their jobs out that is the best outcome, if not then delete the job(s) and update drivers. In any case there will always be some jobs that can cause fatal errors for some copiers/printers.
                  • luca72
                    • Oct 2017
                    • 1784
                    If you already have the latest firmware, the ricoh mc, skip the same version
                    "I'll be back"
                    • ABS tect
                      • Sep 2013
                      • 511
                      I second all this...100% of the time for me it was a bad print job from someone in the office.
                      1) Reset/Cancel all jobs on the MP C3004 itself
                      2) Power Down Machine
                      3) Track down the culprit, hopefully there aren't many users, and clear their print q (you should see the bad job in there)
                      4) Reboot the machine
                      5) Make some money possibly
