MP 2501 copy very clear
  • coccolist
    • Nov 2019
    • 3
    ricoh mp 2501 prints and copies are very clear after replacing the developer, drum and blade. can you help me improve the quality. or is it a defective model? thank you.
  • copier tech
    • 8172
    Re: MP 2501 copy very clear
    Can you post a print sample of the issue?
    Did you replace the drum charge roller?
    • coccolist
      • Nov 2019
      • 3
      [QUOTE=copier tech;2219220] Puoi pubblicare un esempio di stampa del problema?
      Hai sostituito il rullo di carica del tamburo?
      [/CITAZIONE]
      no because before replacing the developer it was not lacking
      • TonerMunkeh
        Professional Moron
        • 3865
        Which developer did you use?
        Hit it.
        • coccolist
          • Nov 2019
          • 3
          D1589640 original type
            • 37532
            Try cleaning the laser shield glass. If you don't know how, call a qualified technician before you totally brick the 2501.
            • KeviM
              • Oct 2019
              • 324
              Check if the dev drive gear is put back on the PCU unit.
                • 37532
                Forgot about that possibility. Had one fall off while sliding the PCU back in on a 2510.
                • KeviM
                  • Oct 2019
                  • 324
                  Yeah, same thing happens to me from time to time.
                  • luca72
                    • Oct 2017
                    • 1784
                    in the case of the gear suggest up, is positioned correctly, you can clean the internal laser box (poligon, mirrors, lens), 8 min. of work, in anycase this it will definitely improve black, check also if the user set "save toner" in user tools print menu
                    "I'll be back"
                    • tullio
                      • Feb 2012
                      • 268
                      Type 28 developer. Ok
                      B1219645
                      • GIUBOSS
                        • 1436
                        B1219645
                        This developer is for mp2000 and for others, the code mentioned in the first page posts is right.
                        • ricohtext
                          • Oct 2022
                          • 20
                          Did you fit an original drum? Some generic drums will cause faint copies. Can you also check your dev bias charge value...
                          • Codex
                            • May 2008
                            • 704
                            +1 for cleaning laser unit (mirrors, polygon)
                            Memento Audere Semper
                            • tullio
                              • Feb 2012
                              • 268
                              I solved with the developer of the ricoh mp2000 - B1219645 - type28 -
