SC 665-02 (MP C2504ex)
  • sharpmind
    • Sep 2009
    • 478
    [Error Code] SC 665-02 (MP C2504ex)
    Guys, have you encountered this kind of error? Updating the firmware is not possible. The SP mode becomes Chinese language. I already replaced BCU and IOB. I removed all the toners and disconnected the development units but still same error is showing in the display. Do you think the NVRAMs in the controller board are corrupted?
    • 37557
    Re: SC 665-02 (MP C2504ex)
    It is more likely to be a bad connection between the BCU and the imaging IOB. See 6.12.5 ISOLATION DIAGRAM OF SC663, 664, 665, 667, 668, AND 670-01 in the service manual.
    • sharpmind
      • Sep 2009
      • 478
      I have not tried yet to replace the flex cable which connects the BCU and IPU. Is it the connection you are referring to?
        • 37557
        Most likely.
        • sharpmind
          • Sep 2009
          • 478
          Most likely.
          According to user, there was a sudden power outage in their office. When the power went back, the SC 665-02 error showed in the machine display. When I come to check it, I restarted the machine several times then SC 682 appears. I cleaned the toner supply unit and the machine was working. I thought i resolved the error. The following day the user called me up again and he said there was SC 665-02 error again.
            • 37557
            There should be a button to toggle through SP mode languages. If I remember correctly it is top right next to the Exit button. Only Available on the main SP menu.
            • anothertech
              • 1771
              I've read in other forums the sc665-02 and the machine displaying in Japanese can be caused by the Transport IOB or the ribbon cable running between that and the Imaging IOB. Might be worth a look.
              It's also sometimes caused by defective toner bottle chips.
              • sharpmind
                • Sep 2009
                • 478
                Problem solved. The error is resolved by replacing the FFC (D2445372) that connects BCU and IOB
                • luca72
                  • Oct 2017
                  • 1791
                  thanks, I will treasure it, it could happen to me too one day
                  "I'll be back"
