Ricoh MP C3004 waste bottle message
  • copierjeffstl
    • Oct 2017
    • 18
    Can anyone tell me what setting to change so that the replace waste toner bottle message doesn't come and shut down machine.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh MP C3004 waste bottle message
    It will have to be emptied or replaced. The machine will not run if it is full.
    NEVER ASSUME ANYTHING
    • DRichard
      • May 2008
      • 482
      "SURPRISE! Your copier is not working, and the best part is it won't tell you why. Have a good day."
      "Enjoy every sandwich."
      -- Warren Zevon
      • DRichard
        • May 2008
        • 482
        Just to be clear...Do you think it is the message that is shutting down the copier and not the fact that your WTB is full?
        -- Warren Zevon
          • 36855
          The service manual tells you how to replace the Waste Toner Bottle. It can be emptied but it is not something I would recommend doing in a customer's office. It is time consuming and runs the risk of making a huge mess. If you are not a Ricoh dealer just search Ricoh 41890 to see where you can buy one. Hell even Amazon has them but wants $22.00. Under $20.00 elsewhere.
          My junior techs and I always carried at least one in our cars. Swap it at the customer then empty it at the shop. For color production machines we always kept one at the customer with the machine.
            • 8103
            When the machine asks you to replace black toner what do you do to make that message go away ?
            • DRichard
              • May 2008
              • 482
              A few of our customers call for a service tech to come out for some vague problem and ask "Oh and could he bring some toner with him when he comes?"
              -- Warren Zevon
              • davidmtupper
                • Jul 2021
                • 326
                We get the same thing all the time, so we're going to start charging for tech delivery of toner any time their shortage is not our fault (backorders mostly). In other words "Poor planning on your part does not constitute an emergency on our part".
                • copierjeffstl
                  • Oct 2017
                  • 18
                  The waste bottle is not full. this keeps happening. I'm a technician. I'm not an idiot.
                  • davidmtupper
                    • Jul 2021
                    • 326
                    If the WTB is not full then you need to find out why the message is displayed. Turning off the message is not a solution, it's a band-aid on a larger problem. Either the sensor is failing or something is causing the diaphragm on the rear top to rise too early.
                    • GIUBOSS
                      • 1382
                      So the tray is not full (actuator sensor lowered) but the machine signals it, it could be the sensor on the machine that is dirty or faulty... Did you also reset the counter?
                      • copierjeffstl
                        • Oct 2017
                        • 18
                        I'm going there today. I'll get back to this thread with more info. I've have reset probably 4 times.
                          • 36855
                          Do you have the service manual? If not then their you are an idiot or you're a really crappy technician.
                          There are at least 4 counters for the waste toner bottles. Have you checked any of them? They are reset automatically when the bottle is properly replaced.
                          There are specific SP entries for both the toner collection bottle full sensor and the toner collection bottle set sensor. Either of those sensors being defective will prevent the message from clearing. Automatic reset of the counters is most likely based on the sequencing of those 2 sensor during replacement. Quite possibly if the machine is not on, the controller will not that sequencing.
                          • MIGUELMARCHENA
                            • Feb 2018
                            • 181
                            Well, I take advantage and tell them: we have a promotion....2 kits of the 4 colors...we take them at once so they don't get stranded...we give 30 days for payment..
                            • luca72
                              • Oct 2017
                              • 1678
                              ALT!...its happened to me the same thing, the current toner bottle, or the previous one, has a toner leak from the rotary gear seal on the back, and fouls the full sensor, you must remove the toner bottle, disassemble the motor-sensor block, and clean the sensor, and change the defective bottle
