op panel firmware for Mp C6004
  • digicor
    • Jul 2008
    • 1153
    does anyone have the FW and the apps software? for the op panel for the mp c6004? I have a sick puppy and need to replace the FW,, i have the blue starburst and nothing else
    thanks
  • GIUBOSS
    • 1435
    Re: op panel firmware for Mp C6004
    thanks
    Have you tried unplugging the hard drive? Have you tried removing accessory electronic boards... I don't think a FW update can start if the machine doesn't start correctly first.
      • 37488
      Have you tried Recovery Mode? Do you know how to boot to recovery mode? You will need it to update the Android OS.
      • copier tech
        • 8144
        thanks
        We can supply this for you if it's still required.
        • digicor
          • Jul 2008
          • 1153
          yes
          • digicor
            • Jul 2008
            • 1153
            yes
            • digicor
              • Jul 2008
              • 1153
              I switched the panel and booted fine
              • GIUBOSS
                • 1435
                Did you solve it by replacing the SOP ?
                • Gift
                  • Mar 2011
                  • 2459
                  Are you able to enter the SOP android service menu/recovery mode? I think you must get that far in order to be able to rewrite the FW or perform a (factory) reset. I was told not to perform factory resets on SOP but it helped me in the past lol.
                  I can send you the file in case you are still in need.
                  • digicor
                    • Jul 2008
                    • 1153
                    yes I can.. please send file
