Ricoh 2800 SC672
  • johnCfu
    • Mar 2020
    • 15
    [Error Code] Ricoh 2800 SC672
    Hi
    I have a RICOH 2800 that while opening displays Please Wait and immediately appears Sc672.
    Any ideas?
    Thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 2800 SC672
    Try formatting or replacing the HDD first.
    Hit it.
    • GIUBOSS
      • 1382
      try here:
      SC672 MPc2800
      • Exodia-P4
        • Jan 2023
        • 123
        You have two choices : ram or controller board
        • dalewb74
          • Feb 2018
          • 1125
          read the service manual? it is full of great ideas.....
          • anothertech
            • 1756
            That's an old machine. Might be time to let it go.
              • 36869
              From Goose's Guide:
              Controller to Op Panel comm error - check connection between controller and op panel
              Controller to Op Panel comm error - replace controller board
              Controller to Op Panel comm error - confirm dip SW #1 is in the OFF position
              Controller to Op Panel comm error - update system fw to 1.14.3 or higher & network
              docbox fw to 1.01 or higher
              • copier tech
                • 8104
                Originally posted by johnCfu
                Hi
                Any ideas?
                Thanks in advance
                Try updating the firmware this may resolve the error. If this fails to update & you get SC672 replace the controller board.
                • Gift
                  • Mar 2011
                  • 2444
                  +1
                    • 36869
                    Originally posted by Gift
                    +1
                    For a Controller-to-operation panel communication error at startup?
                    • anothertech
                      • 1756
                      Yes, the bad HDD can prevent the controller from starting up.
                        • 36869
                        HDD error at startup would be either SC860 or SC861.
