Ricoh MP C401
    • 8121
    Re: Ricoh MP C401
    Originally posted by luca72
    At this point you not have way, invert the nv-ram's, and reset everything...and activate It the nic via so.
    I think your Google translate is broken.
      • 37072
      Re: Ricoh MP C401
      I have no trouble understanding what he posts.
      • luca72
        • Oct 2017
        • 1711
        Re: Ricoh MP C401
        I try not to use Google translate, otherwise I won't learn anymore, only when I'm in a hurry, or I can't remember a word, or some term
        • pinkyman
          • Jun 2022
          • 33
          #19
          Re: Ricoh MP C401
          At this point you not have way, invert the nv-ram's, and reset everything...and activate It the nic via SP
          thanx bro .. can you explain it .. how could i do it
          • pinkyman
            • Jun 2022
            • 33
            #20
            Re: Ricoh MP C401
            this is control pic .. i invert the two bios in the pic but there's no action
            • luca72
              • Oct 2017
              • 1711
              #21
              Re: Ricoh MP C401
              you have to physically access the controller board, and invert the position of the two nv-rams, put 1 on 2, 2 on 1, (be careful, respect the direction of the notch otherwise they burn), then turn on the machine, the first time it goes in Japanese, turn it off again and turn it on again, and it should ask you for an admin password, which you obviously put blank, after you restart it, and go to sp 5-985-001 and enable the NIC with 1, I don't think I something is forgotten.
              anyway see the attachment.
              to switch the language, arrange yourself, you have to see it at the moment
              • pinkyman
                • Jun 2022
                • 33
                #22
                Re: Ricoh MP C401
                i'm already did these steps but the machine run normally without asking any password or anything not normal .. and i can't enter sp mood .. it's driving me wild
                  • 37072
                  #23
                  Re: Ricoh MP C401
                  What exactly happens when you try to get into standard Service Program Mode?
                  • luca72
                    • Oct 2017
                    • 1711
                    #24
                    Re: Ricoh MP C401
                    At second restart, She ask to you a new admin password, (like when the MC its new out the paper box) that you leave blank, this permit you to log in and remove the service SP lock....p.s. i wrote without Google translate ��
                    • pinkyman
                      • Jun 2022
                      • 33
                      #25
                      Re: Ricoh MP C401
                      When i reverse the two v ram and start up the machine it wrote 🇯🇵 Japanese letters and freeze like that pic in attachment without any action .. i let it about one hour and the situation as it is
                      • luca72
                        • Oct 2017
                        • 1711
                        #26
                        Re: Ricoh MP C401
                        When i reverse the two v ram and start up the machine it wrote ���� Japanese letters and freeze like that pic in attachment without any action .. i let it about one hour and the situation as it is
                        Seem that She Say "restart the machine"...and next step its retype the admin password (leave blank two time)...anyway try to catch a photo in Google translate to know what wrote...dont worry, be Happy, I've done this process dozens of times, never a problem��
                        • pinkyman
                          • Jun 2022
                          • 33
                          #27
                          Re: Ricoh MP C401
                          I translated it by google it says preparing for firmware update and stopped as it is
                            • 37072
                            #28
                            Re: Ricoh MP C401
                            Log in as admin & go to administrator tools tap most likely its been disabled there.
                            Looks like he needs SD card firmware before he can do anything else.
                            • luca72
                              • Oct 2017
                              • 1711
                              #29
                              Re: Ricoh MP C401
                              yes, i think that systemcopy file only its sufficient.
                              • pinkyman
                                • Jun 2022
                                • 33
                                #30
                                Re: Ricoh MP C401
                                How could i get the firmware.. i have sd card but i need the rom file
