Ricoh MP C401
    • 37072
    #31
    Re: Ricoh MP C401
    Originally posted by pinkyman
    How could i get the firmware.. i have sd card but i need the rom file
    Private message copier tech.
    • luca72
      • Oct 2017
      • 1711
      #32
      Re: Ricoh MP C401
      Tomorrow morning i try to send you a systemcopy rom file via PM
      • pinkyman
        • Jun 2022
        • 33
        #33
        Re: Ricoh MP C401
        Thnx pro
        • luca72
          • Oct 2017
          • 1711
          #34
          Re: Ricoh MP C401
          Thnx pro
          I'm sorry, but today I'm not in the lab, and from home I don't have access to the ricoh portal to download the systemcopy for you, you should write where slimslob said, which lets you get it first, specify your region, because the file could be different
          • GIUBOSS
            • 1385
            #35
            Re: Ricoh MP C401
            I'm always kept away from NVRAM except to replace them with new ones, I'd risk blowing up the controller board. As well as losing all factory settings/adjustments
            • luca72
              • Oct 2017
              • 1711
              #36
              Re: Ricoh MP C401
              Originally posted by GIUBOSS
              I am always kept away from NVRAM if not to replace them I would risk blowing up the Controller Board. As well as losing all factory settings/adjustments
              Lately I've had to deal with , I often play this trick never had problems, it usually solves them, however every now and then they break down on their own, and I replace them following the SM procedure, you can also put different ones, for example I put that of 2501 on 4054, and it worked....if you cant do more, i use this...let's call it "the trump card"
              • pinkyman
                • Jun 2022
                • 33
                #37
                Re: Ricoh MP C401
                • luca72
                  • Oct 2017
                  • 1711
                  #38
                  Re: Ricoh MP C401
                  i’m from Egypt ����
                  can you send me the firmware Link ?
                  inviato, check your PM, i put also the istruction
                  • pinkyman
                    • Jun 2022
                    • 33
                    #39
                    Re: Ricoh MP C401
                    SD Card must be one Giga or less not more ?
                    i have 8 giga one !
                      • 37072
                      #40
                      Re: Ricoh MP C401
                      i have 8 giga one !
                      You can use a utility such as MiniTools Partition Wizard to create a 1 GB partition.
                      • luca72
                        • Oct 2017
                        • 1711
                        #41
                        Re: Ricoh MP C401
                        great MTPW, I use it very often
                        • luca72
                          • Oct 2017
                          • 1711
                          #42
                          Re: Ricoh MP C401
                          i have 8 giga one !
                          • pinkyman
                            • Jun 2022
                            • 33
                            #43
                            Re: Ricoh MP C401
                            thank you guys for your attention ... but this machine drive me wild .. i did firmware update that you sent me and it done very well .. but everything as it is .. i still can't enter SP mood by Y 806782 C and still no interface settings no NC no USB ..
                            i want you to notice that cable in the pic i pointed on it in the pic there is no socket for it .. maybe it is do something !!!!
                            • pinkyman
                              • Jun 2022
                              • 33
                              #44
                              Re: Ricoh MP C401
                              thank you guys for your attention .... i did firmware update and it done very well .. but everything as it is .. i still can't enter SP mood by Y 806782 C and still no interface settings no NC no USB ..
                                • 37072
                                #45
                                Re: Ricoh MP C401
                                Looking at illustration d191b0056 in the service manual for replacing the IPU, that portion of the harness is supposed to go above the IPU and to something under either the IPU or the Controller. You may need to lift the IPU and controller and look for where it goes. Ricoh used to be real good at putting at least one connector on the bottom of at least one PCB.
