Ricoh SP 8400 Mono Printer splitting up large print jobs
  • GIUBOSS
    • 1385
    #16
    Re: Ricoh SP 8400 Mono Printer splitting up large print jobs
    I'd also take a look at the error log just in case
    • patterson70
      • May 2010
      • 599
      #17
      I went there today and saw for myself how it splits up the print job.
      For example for a large 400 page two set job (200MB) he printed, maybe half of the file printed out and then there is a separator page printed, and then it repeats this for the second set.
      Then it prints out the second half of the job and repeats it. It cannot RIP the entire file and print out complete sets.
      It does this with the PCL6 driver as well as the Adobe driver.
      I also did the firmware update and it did not make a difference.
      This is why I am asking if adding the HDD option would resolve this issue but not one knows for sure.
      He does not want to pay for it unless I can guarantee it will solve the problem and I don't have another one available to test. There is no error showing up.
      I guess no one has seen this issue so far but thanks for all the suggestions.
        • 37357
        #18
        To me, the fact that it prints the first half of the document twice with a separator sheet between then repeats for the rest of the document sounds more of a document format or software problem that a printer problem. For some reason the 8400 is receiving an End Of File or End Of Job code instead ad End Of Page code/ Or maybe a Separator Page command where there should be a New Chapter Command that the 8400 is interpreting as an End of File code.
        • GIUBOSS
          • 1385
          #19
          Try resetting the printer and settings. However remove the old installed driver and download the new one.
          • Gift
            • Mar 2011
            • 2458
            #20
            Yes totally
            It makes no sense - even if the printer can't handle to process the data in one step it won't throw out a separator page unless some weird setting is active at some point.
            I think you need to start making clear this has nothing to do with the printer at all. Before having this talk you must prove your statement by running a print job that is at least as "complex" spool-data and page-count wise from your laptop with a clean driver. I bet there will be no separator pages in this scenario. I don't know how these print jobs are beeing generated but I guess it's some sort of proprietary software solution.
            • patterson70
              • May 2010
              • 599
              #21
              I meant to say that the customer actually purposely set the printer to input the separator sheet because it will let you do that at least. It has not effect on the splitting of the sets. It will split the sets up regardless of the separator sheet. This way he does not have to hunt for each set.
              I am almost convinced the HDD will solve his issue but he still will not buy the HDD just to find out. Can't blame him. Thanks to all for your suggestions.
              Originally posted by Gift
              Yes totally
              • copyboy99
                • Jan 2020
                • 23
                #22
                please print "print list " from Interface tools.
                Check TCP timeout settings (this is for DIPRINT protocol), most likely it will be 15 seconds,
                please update it this via Telnet to 300 seconds or more.
                Diprint Timeout settings.pdf
                see attached instructions.
                • patterson70
                  • May 2010
                  • 599
                  #23
                  [ATTACH]61066[/ATTACH]
                  Thank you. I did look into this but the DIprint setting being too low would result in the job being reprinted. In this case the job is being split up. So lets say 10 sets, it will print half of the document for set 1, half of set two, etc until set 10. Then it will print the second half of set 1, the second half for set 2, and on.
                  Somehow the user figured out how to insert a separator page to help him mark where they stop. It was doing this before he figured out how to insert the separator page, so that has nothing to do with it spliting the document up.
                  I told him it looks like he is running out of RAM memory. But the document is no where near the 2GB memory that the machine has (not upgradable).
                    • 37357
                    #24
                    That 2 GB of RAM is not just page memory. It is mostly system memory.
                    What is the software?
                    Are there any Chapter Breaks in the document at the point where the document is split?
                    Are multi-copies controlled by the computer or the printer?
                    • csliao
                      • Oct 2021
                      • 33
                      #25
                      您好,有一位客戶使用 SP 8400 (11" x 17") 單色印表機。
                      當他發送一份大型列印作業(例如五套)時,它並不總是一次列印整套。
                      它會列印部分集,然後列印文件的其餘部分。因此,印刷完成後,他必須手工組裝它們。
                      RAM 為 2GB,不可升級。
                      如果他買選購的 320GB 硬碟,問題就能解決嗎?
                      我不想賣給他一個,那也沒用。我還沒賣過這個型號的硬碟。
                      你可以安裝硬碟(型號p13),320GB或更多,500GB以上
                      開啟主電源。
                      HDD 的初始化(格式化)自動開始。
                      10. 列印“設定頁”,然後檢查該選項是否已正確識別。
                      • 使用者工具> 機器功能> 印表機功能> 清單/測試頁> 設定頁
                      11. 在印表機驅動程式的「進階選項」標籤中選擇「HDD」。
                      請依照以下步驟以 Windows 7 為例;
                      (1) 指向“開始”功能表>“裝置和印表機”,然後右鍵單擊印表機圖示。
                      (2) 按一下“印表機屬性”,然後按一下“進階選項”標籤。
                      (3) 選擇「硬碟」。
                      or use Ricoh print driver preferences,work type,File server, use printer HDD,
                      • patterson70
                        • May 2010
                        • 599
                        #26
                        Thank you, I did not know that about the 2GB, thought it was all for printing!
                        They are Adobe PDFs.
                        No, it splits the documents on it's own.
                        Not sure what you mean, he tells the driver 10 sets and it prints the 10 sets, just half of them at a time.
                        I really think it is running out of memory and this is how it deals with it.
                        But as i said, he does not want to commit to the HDD unless I can guarantee him that will fix it.
                        He can live with it since he only prints three large size docs like this a month, but it's a pain to have to assemble them.
                        He had a Xerox 5550 before and he loves the SP 8400 (except for this problem) for what that's worth. Does about 30K a month.
                        • patterson70
                          • May 2010
                          • 599
                          #27
                          Thank you but I can't read this!
                          • patterson70
                            • May 2010
                            • 599
                            #28
                            Oh, I tried google translate and it worked! However, he did not read my information completely.
                            See below:
                            • anothertech
                              • 1760
                              #29
                              You can just throw any HDD in there, you don't need to buy one from Ricoh. Do you have another machine laying around that you could borrow the HDD from?
                              • patterson70
                                • May 2010
                                • 599
                                #30
                                Thank you for this. I will check into this. Thank you again.
