Richo network firmware?
  • tonerdust
    • Sep 2023
    • 1
    [CQ] Richo network firmware?
    What is the consensus regarding the firmware in Richo machines? I've got a RICOH SP C261SFNw PCL 6. As a printer its great but setting up the network software is just not something I have been able to do. I've worked with Dell,IBM, Lexmark, cannon,hp all of them and have been sucessful setting them up. When I first got this printer I just connected to it via USB and then shared it. Recently, I decided to take advantage of its networking functions, wifi, air print etc. but I just can't get anything to make sense let alone work. The menus and resulting actions are just not valid and the docs are not consistent with the printer. I am wondering if
    the networking firmware has gotten corrupted? time to install an update despite the fact that it is at the proper level?
  • copier tech
    • 8174
    Re: Richo network firmware?
    What exact issues are you having when you try to install the driver?
    We can supply you with the latest firmware for this model should you want to update it.
      • 37532
      Since you mention WiFi, I'm wondering if you are turning on IEEE802.11 to setup WiFi? If so that is your problem. For it to work requires Ricoh's extremely over priced WiFi interface be installed. Without the interface all IEEE802.11 does is turn off the wired interface. If you only have WiFi your best option is a WiFi Extender.
      One more thing, all interface settings require that you cycle power before they become functional.
      • GIUBOSS
        • 1436
        You should specify if you have a printing problem (The menus and resulting actions are just not valid and the docs are not consistent with the printer. I am wondering if...) or connection with wifi. For example if you use the LAN cable you have to set the fixed IP and not the WSD port, PCL6 driver.
        • dalewb74
          • Feb 2018
          • 1157
          i totally agree with slim. do NOT try to use the built in wifi. its junk.. i would hard wire it and let it bump. that should resolve all your issues.
