Component Control on Ricoh MP C3004ex?
  • nanoaxl
    • Nov 2022
    • 2
    Hi,
    I'm a printer technician who is used to Xerox printers and there is a feature on some of those machines called Component Control - it allows you to switch on specific parts of the machine for troubleshooting i.e. switching on a motor.
    I am working on a Ricoh MP C3004ex and there is a squeaking sound coming from the right side of the machine. Is there a way to troubleshoot exactly where the squeaking is coming from?
    Any help would be appreciated.
    Thanks!
  • anothertech
    • 1768
    Re: Component Control on Ricoh MP C3004ex?
    Go into service mode, find the Output mode, I think it's SP5804. You can run the different motors in Output mode.
    • Larhal
      • 568
      Yes there is. First thing you need is a Service Manual.
      Larhal
      If all else fails read the Service Manual!
      If that fails, meet me at the pub and we will discuss it.
      • nanoaxl
        • Nov 2022
        • 2
        Okay, thank you very much! Found Output mode and was able to turn on some of the components individually.
        • dalewb74
          • Feb 2018
          • 1151
          if you can get it from ricoh. customer engineer tool. this is a special tool that will do what you are trying to do. but you will also need ricoh authorized access. this is a special tool for techs to use. if you are not a ricoh tech., then i would say you wouldn't be able to get it, nor access it.
          • luca72
            • Oct 2017
            • 1775
            Originally posted by nanoaxl
            Hi,
            Thanks!
            try taking a look at this one, the model is the previous one, but the mechanics are the same, this could very easily be your case
            "I'll be back"
