IM C4510 ITB Unit
  • Larhal
    • 583
    IM C4510 ITB Unit
    Hi All,
    I have been asked to replace an ITB unit in a IM C4510. I no longer have access to Ricoh Technical. All I would need to know is if there is a difference in procedure and reset (SP3-701-93) than an IM C4500?
    Any tips would be greatly appreciated.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • RicohBoomer
    • May 2022
    • 40
    Re: IM C4510 ITB Unit
    Looking at the manual the process looks pretty much identical to the IM C4500. I haven't had to replace one in the field yet but have replaced plenty of belts on the XX04 series which I believe is very similar to the IMC.
    If you are tasked with replacing a whole unit then it is even easier since the SP mode you brought up is the same as on the IMC.
    • Larhal
      • 583
      Thank you RicohBoomer. I appreciate the information. Yes complete ITB unit. Is the ITB Cleaner similar?
      Larhal
      • luca72
        • Oct 2017
        • 1783
        Originally posted by Larhal
        Hi All,
        it's the same thing, don't worry, the only thing to know, is that if you change the complete new itb unit, the cleaning unit is not provided, you have to dismantle it from the old one or replace it with a new one
        "I'll be back"
        • Larhal
          • 583
          There will be a new cleaning unit also at the customers tomorrow. Thanks Luca.
          Larhal
          • Larhal
            • 583
            Thanks to all, the replacement went extremely smooth.
            Larhal
            • anothertech
              • 1771
              What happened to the original ITB unit? Failed early?
              • Larhal
                • 583
                It had 345K pages on the clock, combined K and CMY. Another tech had diagnosed it with a defect. When I pulled the old one there was a dimple on the belt which would give a mark on the print . How that happened I could not tell you.
                Larhal
                • copier tech
                  • 8167
                  Hi All,
                  Yes the same or from the first service mode page you have a PM counter option, you can choose manual new unit set for the transfer unit. (no need to remember as many SP modes)
                  • Larhal
                    • 583
                    Thank you for the information.
                    Larhal
